Old 11th July 2003, 02:23 PM   #11
MWP is offline MWP  Australia
You can use common TO3 insulators by cutting them in half.
Old 11th July 2003, 04:43 PM   #12
Account Disabled
Originally posted by Netlist
There are silpads available in larger formats (100x100mm) which you can cut into the desired format.
does anyone know where I may be able to get those sheets in the US?
Thanks.
Old 11th July 2003, 05:05 PM   #13
JOE DIRT®'s Avatar
silpad is very expensive.....I purchased a 12" wide roll for a production run and it was a 1000CAN.....we used a paper cutter to cut the required size which increased labour costs....I regret approving the decision now
DIRT®
Old 11th July 2003, 06:04 PM   #14
Thanks.
Maybe Digikey... ...I order sillpads from there... ...but not sheets.
-With a bad amp, everything sounds the same. It takes a good amp to tell the difference between true "Artists" and the rest of the "Performers".
Old 14th July 2003, 03:13 PM   #15
chris ma's Avatar
Originally posted by Peter Daniel
Plastc screw is OK when not much pressure is required (diodes), but on ICs and transistors, I'm using metal screw (non magnetic) and a plastic washer (I buy from Supremetronic).
Are those plastic washer are just normal flat ones, I am concern about the shaft of the screw may make contact with the inside surface of the heat sink thru hole. May be I have to use heat shrink on the screw first?
Old 14th July 2003, 03:14 PM   #16
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Those are washers designed for that purpose. They have additional lip, that prevents the screw from touching the case.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 14th July 2003, 03:19 PM   #17
Account Disabled
Chris, like Peter said, those washers have extra-long "sleeves" that do precisely that: preventing the screw from touching the heatsink.
I have been using plastic tubing for that purpose as well.
Old 15th July 2003, 12:14 AM   #18
AKSA is offline AKSA  Australia
Since TO-220s normally run around 1W dissipation or thereabouts, I normally just use a simple bolt on heatsink like a THD6080 and don't even bother with insulation. This improves thermal coupling, and since the heatsink is small anyway you can usually tolerate it being at collector potential.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 15th July 2003, 04:57 AM   #19
The rest of a thread is here: http://www.diyaudio.com/forums/showt...608#post204608
www.audiosector.com
Isolating a hum? Bogie Solid State 10 26th January 2005 01:14 PM
Isolating each Mos-Fet? richeros Solid State 14 13th April 2003 10:19 PM
Copyright ©1999-2013 diyAudio
