| Chip Amps Amplifiers based on integrated circuits |
Tried to search for this and I am sure the answer is a simple one.
Got hiss coming through on mids and tweeters and once input is shorted out it disappears. The input is coming from the PC if that makes a difference. What is the fix for this Also idle temp is around 40 degrees. Is this normal. The heatsinks are Dynatron CPU sinks and appear more substantial than some projects I have seen. Cheers Wizard |
#2 | |
Err.. if the hiss goes when input is shorted, but is there when PC is connected, it seems to me it is coming from the PC! No? Or, if it is running hot at idle, it is oscillating. |
#3 |
Turn the volume control on the PC to maximum and install a fixed attenuator to still allow you to get a useful volume range from the control. That helps to increase the SNR.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#4 |
Many thanks Star
47k low noise audio pot sorted it out |
| Hiss but no hum... | RockysDad | Tubes / Valves | 13 | 5th April 2009 06:35 PM |
| Hiss in my P3a Amp | blap0220 | Solid State | 15 | 1st June 2007 02:52 AM |
| Fullrange hiss ? | mirland | Full Range | 14 | 28th September 2005 12:43 PM |
| BrianGT's LM3886 board, and hiss | Russ White | Chip Amps | 9 | 20th March 2005 09:10 PM |
| hiss | jaudio | Chip Amps | 21 | 6th March 2005 06:02 PM |
| Page generated in 0.08473 seconds (67.65% PHP - 32.35% MySQL) with 10 queries |
