| Chip Amps Amplifiers based on integrated circuits |
Hello everyone!
I recently bought the lm3886 stereokit from BrianGT, and while looking for a trafo I found a broken Monacor DSR-200 surround reciever at home, I decided to take a look at the trafo, to see if I could use it. The trafo is rated at 520VA at 230v I removed the trafo and connected it, I measured the ac voltage on the outputs. This is the results: 1+2=21v 1+3=42,5v 1+4=21v 1+5=29v 1+6=59v 1+7=90v 1+8=98v 1+9=10v 1+10=8v 2+3=21v 2+4=3v 2+5=11v 2+6=41v 2+7=71v 2+8=79v 2+9=1v 2+10=3v 3+4=15v 3+5=7v 3+6=23v 3+7=53v 3+8=61v 3+9=11v 3+10=13v 4+5=9v 4+6=45v 4+7=81v 4+8=90v 4+9=2v 4+10=3v 5+6=35v 5+7=71v 5+8=81v 5+9=6v 5+10=7v 6+7=35v 6+8=45v 6+9=20v 6+10=22v 7+8=9v 7+9=35v 7+10=36v 8+9=38v 8+10=40v 9+10=5v I hope it didnt get to messy. When I measure if the pins are connected to eachother (Ω=0 Ohm) I get the follow results: 1+2+3=connected 4+5+6+7+8=connected 9+10=connected Oh well, I've got no clue what this means and I've got no clue at all how to connect it to the PSU. Softstart required? Anyone mind giving me some help on how this work, and which pins to connect to what. Adding some photos for you: ![]() ![]() ![]() Thanks Maxhax |
#2 |
first:disconnect the mains.
second: find which outputs are on a common winding and how many windings it has. third:connect the mains via a light bulb tester. fourth: measure the voltage ONLY across terminals of a single winding. Measure each winding and all it's tappings separately. Now tabulate your results.
regards Andrew T. |
#3 | |
Thanks for the fast answer, I'll build a light bulb tester asap.
#4 |
a multimeter set to low ohms or continuity. Or a battery and a light bulb.
regards Andrew T. |
#5 |
Oh, I think I already did that.
If you read "When I measure if the pins are connected to eachother (Ω=0 Ohm) I get the follow results: 1+2+3=connected 4+5+6+7+8=connected 9+10=connected" My english isn't that good, might explain a few things |
#6 |
if 9 & 10 are the same widing and NOT connected to any other tap, then DO NOT measure 9 to any other tapping nor 10 to any other tapping.
Similarly, if 1, 2 & 3 are on one winding then do not measure any of these taps to any other tap. Now repost the correct data.
regards Andrew T. |
#7 | |
I realise you are providing some education on how to do this properly. The information is all there, just messy with a great deal of redundant info. Maxhax, 1,2 and 3 are a 42V centre tapped winding. Pin 2 is the centre tap. Let's call this winding A. 4,5,6,7, and 8 are winding B. Pin 6 is the centre tap. Using 4,6 and 8 you have a 90V centre tap, using 5,6,7 you have a 70V centre tap. 9 and 10 are a 5V winding lets call this Winding C. Assuming bridge rectification Winding A will give you around +-30V DC Winding B taps 4,6,8 will give you +- 64V DC Winding B taps 5,6,7 will give you +- 50V DC Winding C will give 7 V dc. The only winding suitable for a 3886 is winding A. The question you need answered and I can't answer it from the info supplied is how much current winding A will give you. It will not be any where near 520VA. Winding B is the winding with all the current. If you have a look at the donar amp you will probably find some chip amps. Count them up and look at their data sheets. This will tell you what the chips need in terms of current. Otherwise find a service manual or schematic for the donar and see if that gives you any more info. All above voltages are approximate. Terry
What we don't understand is called magic. |
#8 |
Okey, this seems to be it:
Winding 1: 21v, 21v and 42.5v. Winding 2: Really many, not sure how to measure this. Winding 3: 5v Is this possible or am I totally wrong? |
#9 | |
I'll look up the chips on the amp asap I get back home. Max |
#10 |
By the way, some of those higher voltages on your trafo can kill you. Please be careful.
Terry
| why bass is tight and controlled on SS than chipamps like lm3886? | rhythmdiy | Solid State | 46 | 14th December 2008 02:32 PM |
| Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? | rhythmdiy | Chip Amps | 9 | 23rd October 2007 01:30 AM |
| Chipamps and more for sale | sbrtoy | Swap Meet | 4 | 3rd July 2007 06:17 PM |
| Ground LM3886 chipamps | chevy2410 | Chip Amps | 2 | 9th May 2007 09:39 PM |
| Chipamps and distortion | Pan | Chip Amps | 0 | 19th November 2003 07:29 PM |
| Page generated in 0.12692 seconds (82.07% PHP - 17.93% MySQL) with 10 queries |
