| Chip Amps Amplifiers based on integrated circuits |
#21 |
I am building my chip amp up into an integrated amp, by using the B1 buffer board and an as yet undecided RIAA phono stage (when they arrive).
My question is this: How do I get more inputs into the B1 buffer? It comes with two, but after DAC and phono, I'd like another for tuner, and preferably another for AUX use. Ideally the DAC and phono and AUX would be line level inputs, but shouldn't the tuner input be lower than line level volts, or are most tuners outputting line level these days? Many thanks Lucas
Lucas |
#22 |
Find a rotary double switch with enough positions to suit your input needs.
Any solution is a compromise. |
#23 |
Ah, I guess it really is that simple...so why are there two separate inputs on the B1 board?
Lucas |
#24 |
If you refer to this:
http://passdiy.com/pdf/B1%20Buffer%20Preamp.pdf then it's probably because Mr Pass didn't need more inputs.
| LM3875 as a voltage buffer? | audio_moksha | Chip Amps | 4 | 7th December 2008 04:41 PM |
| Tube buffer PCB for LM3875 | neil_kaye | Chip Amps | 0 | 28th August 2006 03:20 PM |
| Looking for Tube buffer board for LM3875 | neil_kaye | Swap Meet | 0 | 28th August 2006 02:00 AM |
| Look for tube buffer for inverted LM3875 | Mrpong | Chip Amps | 7 | 26th July 2006 08:18 AM |
| I'm looking for LM3875 chip??? | thomgun_lc | Chip Amps | 5 | 3rd January 2006 07:26 AM |
| Page generated in 0.07839 seconds (72.58% PHP - 27.42% MySQL) with 11 queries |
