Old 21st October 2009, 05:01 PM   #1
ryan750 is offline ryan750  Philippines
Default parallel lm3886 with 1% resistors
when using a 1% tolerance resistor, for example, let's say for a parallel lm3886 and a non inverting input the worst case voltage gains is I think 23.44 and 22.56
and for example I've paralleled this two chips driving a 4ohm load.
is there any formula on obtaining the power dissipation on each IC's???
does lowering the supply voltage a little bit would compensate for the gain mismatch and possibly lowers the power dissipation below 40w which national specifies?????
Old 21st October 2009, 05:44 PM   #2
use +-1% resistor but accurately match them to better than 0.1%
regards Andrew T.
Old 21st October 2009, 11:37 PM   #3
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Yep, that's a good idea. However one caveat - 1% resistors tend not to have such good temperature coefficients as 0.1% ones. So the match you achieve with your DMM might well degrade at the working temperature of the amplifier.
Parallel TDA2052 vs Parallel LM3886 for subwoofer goldyrathore Chip Amps 22 22nd November 2009 03:34 PM
LM3886 parallel output resistors jmar Chip Amps 10 23rd October 2009 02:43 PM
FS: Resistors, LM3886, speaker terminal, variable resistors, switches and rectifiers chris-man Swap Meet 1 28th May 2009 12:47 PM
DHT and resistors in parallel w/ heater yagoolar Tubes / Valves 13 7th November 2004 09:17 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 11:24 AM
Page generated in 0.07817 seconds (68.38% PHP - 31.62% MySQL) with 10 queries
