| Chip Amps Amplifiers based on integrated circuits |
#11 |
That's EXACTLY why I'm interested in these.
To use with an active system. Audio is so full of contradiction, that I get distracted, and the past few days I've been thinking of building one of these 4" full range speakers systems (Fostex 127e in a vented box -- I'm sure you've seen the "hoopla"). I have a subwoofer and listen at low volume levels anymore, so it may be worth trying -- if I like it I may skip my active plans for now. But I don't know -- the original plan was to use the sub and an MTM speaker which setup the need for (1) mixed mono sub amp with 2 LM3886 in parallel (1) stereo LM3886 for the low/mid (probably not enough power) and (1) stereo LM3886 for the tweeters. I have a USB preamp already built and thought I'd add the crossover to the board with maybe a simple jumper system on the board itself for crossover points. I've been wanting to do something that in theory is a vast improvement over conventional passive crossovers and "a stereo amp". Have you ever heard the 4" full range speakers in a bigger box? I must admit when they are used in near field monitors they sound incredible. |
| Parallel TDA2052 vs Parallel LM3886 for subwoofer | goldyrathore | Chip Amps | 22 | 22nd November 2009 02:34 PM |
| FS: Resistors, LM3886, speaker terminal, variable resistors, switches and rectifiers | chris-man | Swap Meet | 1 | 28th May 2009 11:47 AM |
| Parallel LM3886 output resistor(s) | markiemrboo | Chip Amps | 4 | 22nd July 2007 09:03 PM |
| Parallel DACs: How many I/V resistors ? | Bernhard | Digital Source | 7 | 18th March 2007 12:48 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 10:24 AM |
| Page generated in 0.08731 seconds (68.09% PHP - 31.91% MySQL) with 10 queries |
