Compact Sized LME49810/11 +ThermalTrak Amp
Old 15th December 2009, 04:58 AM   #41
panson_hk is offline panson_hk  Hong Kong
panson_hk's Avatar
Originally Posted by traw View Post
Ah ok... I thought maybe there was some rule of thumb could use to choose right ballpark of current, guess experiment away. Need to get scope.
May be there are guidelines. Let see other replies.
Old 8th February 2010, 04:29 AM   #42
panson_hk's Avatar
Originally Posted by blueskynis View Post
Hello Panson,
about possible compensation optimization. Have you tried it?
Please take a look this Comparing LME49810, 49830 and 49811
Old 8th February 2010, 10:51 AM   #43
blueskynis is offline blueskynis  Serbia
blueskynis's Avatar
Will do. Thanks.
Windows-free with Linux
Old 8th February 2010, 03:35 PM   #44
Radioman62 is offline Radioman62  Sweden
Default Output inductor & Zobel network
Hi panson
A question about using your compact amplifiers inside active speakers. One amp to each element.
Is it really necessary to use those inductors and Zobel network when the connections between amplifier and speaker is only about 10 inch?
The answer is maybe the same for any other typical audio endstage?
Cheers// Ove
Old 8th February 2010, 05:22 PM   #45
R.I.P.
at very high frequencies the inductance of the Voice coil and the capacitance of the cable may not provide a nice benign load for the amplifier.
The Zobel guarantees an R+C load at VHF and this helps stabilise the amp.
regards Andrew T.
Old 9th February 2010, 01:15 AM   #46
panson_hk's Avatar
Originally Posted by Radioman62 View Post
Hi panson
Hi Radioman,
As AndrewT you need to take care of voice-coil inductance. However, cable effect is negligible for direct connection. I would recommend to have those parts to avoid problem in this part.
Old 9th February 2010, 01:17 AM   #47
Sebastiaan is offline Sebastiaan  Netherlands
Dear,
Always use the zobel and the output inductor/resistor.
I was stubborn and did it without (also active speaker project) but on some occasions I got oscillations in the far MHz. The Zobel solved this problem.
With kind regards,
Bas
Old 23rd February 2010, 02:35 AM   #48
panson_hk's Avatar
Default New Compact 4981x ThermalTrak board being made
I revised the schematic to include Vbe multiplier, two-pole compensation and ThermalTrak diode current by-pass. We now have many things to try!!!
The new board is being made. Here is the new schematic.
Old 23rd February 2010, 03:35 AM   #49
Dear Panson.
What is your reason to add the VBE transistor? My understanding was that the benefit of the Thermaltraks was that you don't need a VBE transistor anymore.
With kind regards,
Bas
Old 23rd February 2010, 03:40 AM   #50
panson_hk's Avatar
Originally Posted by Sebastiaan View Post
Dear Panson.
With kind regards,
Bas
Hi Bas,
Good question! This is added for user to compare different bias schemes. I want users to have more fun with the new board. We can do simple bias with solely TT diodes, conventional Vbe without using TT diodes, Leach like Vbe with TT diodes, etc.
Panson
Compact Sized LME49810/11 +ThermalTrak AmpHide this!Advertise here!
On Semi ThermalTrak davidallancole Solid State 639 1st May 2013 02:29 AM
LME49810 plus ThermalTrak single-board layout panson_hk Chip Amps 1 28th September 2009 10:57 AM
LME49810 W/ Thermaltrak CFP Output BarryJF02 Chip Amps 6 13th September 2009 12:23 AM
OnSemi ThermalTrak Arius Solid State 8 26th August 2005 04:09 PM
In search for a compact sized motorized pot yairf Parts 1 19th October 2004 02:56 PM
