Compact Sized LME49810/11 +ThermalTrak Amp - Page 29 - diyAudio
Old 28th August 2012, 06:59 PM   #281
dirkwright's Avatar
Originally Posted by klewis View Post
You probably won't come up with a matched pair. Just adjust the Re resistors to get a reasonable balance between the p and n.
That's fine for DC but not for AC.
Old 28th August 2012, 07:31 PM   #282
klewis is offline klewis  United States
klewis's Avatar
You may know more about this than me, but, I (and several others ) used it to good effect on the Fetzilla Amp where we couldn't find matched pairs.
Old 28th August 2012, 08:24 PM   #283
dirkwright's Avatar
I've been reading Bob Cordell's book. It's excellent!
Old 28th August 2012, 11:52 PM   #284
jackinnj's Avatar
I don't see NJL3281 and NJL1302 on your site.
You have 2 flavors to choose from. If you read all the datasheets...
Old 29th August 2012, 12:44 AM   #285
/just posting here to subscribe.
I'm almost finished building one of Panson's compact amps, the build has gone well, and initial testing is promising.
Fran
Old 13th November 2012, 04:29 PM   #286
Panson, i suspect that if you'd put your driver transistors on the same heatsink as the thermaltraks' your bias-drift problems will be over. No need for extra diodes..
Old 13th November 2012, 08:40 PM   #287
panson_hk's Avatar
Hi, I prefer the drivers temperature not being modulated by the output devices.
Old 23rd November 2012, 04:13 PM   #288
Idefixes's Avatar
Send a message via ICQ to Idefixes
Hi panson,
I bought 2 of your latestet revision board from someone that forgive project. I purchase all parts i needed as i have some as driver and transistors on hand. I have choice for ThermalTrack Unit between NJL3281/1302 and NJL42381/4302. Do you see an issue in using the second one as it has better SOA charts? I have MJE15030/15031 to but also 2SC5171/2SA1930. Could it be some stability issu in using this faster devices instead of MJE brand?
Marc
website : http://audiyofield.wifeo.com/index.php
Old 23rd November 2012, 08:58 PM   #289
panson_hk's Avatar
Originally Posted by Idefixes View Post
Hi panson,
Marc
Hi Marc,
No problem at all to use 4281/4301. I used have them.
It should be find to use 5171/1930 to drive one pair ThermalTrak in this Compact Amp, though their current rating is lower.
Panson
Old 24th November 2012, 07:50 AM   #290
Idefixes's Avatar
Originally Posted by panson_hk View Post
Hi Marc,
Panson
Tanks for reply, i know 5171/1390 current rating are lower as 15030/15031 but for +/-35Vdc rail use and driving one pair NJL4281/1302 it's more then enough i think, my only concern was on stability issue as they are a lot faster as onsemi devices.
Marc
On Semi ThermalTrak davidallancole Solid State 639 1st May 2013 02:29 AM
LME49810 plus ThermalTrak single-board layout panson_hk Chip Amps 1 28th September 2009 10:57 AM
LME49810 W/ Thermaltrak CFP Output BarryJF02 Chip Amps 6 13th September 2009 12:23 AM
OnSemi ThermalTrak Arius Solid State 8 26th August 2005 04:09 PM
In search for a compact sized motorized pot yairf Parts 1 19th October 2004 02:56 PM
Copyright 1999-2017 diyAudio
