Compact Sized LME49810/11 +ThermalTrak Amp
Old 13th March 2012, 03:23 PM   #271
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Originally Posted by panson_hk View Post
You can add zener diodes as simple regulator. If I were adding a regulator for the front end, I will use linear regulator.
Do you use conventional output devices instead of ThermalTrak? Vbe multiplier can be MJE15030.
Why do you use small cap for C8?
Well, I'd prefer a linear regulator as well but that would be messy to add to the board. I prefer neat and orderly over messy and complicated.
I'm going to use the output transistors that you recommend, which I guess are the Thermal Trak. Are you saying that if I use the TT, outputs I don't need a Vbe multiplier? I'm not very experienced with all of this so pardon my confusion.
As for C8, bypassing a zener diode in a simple regulator circuit with a capacitor usually has the function of shorting the high frequency noise from the zener to ground. A big electrolytic is going to have too much inductance at high frequencies to effectively shunt the zener noise to ground. Normally, a small ceramic or mica capacitor is better at this kind of function. This may not be a big deal in the +5volt circuit but I'm just stating generalities here.
Old 13th March 2012, 03:34 PM   #272
atupi is offline atupi  Romania
Hi, One pair ThermalTrak NJL3281D/1302D is enough for 50 W / 8 Ohms. Very safe for driving reactive loads as well. You need to adjust bias setting, nothing more. Are you doing stereo amp?
Yes i want a stereo version for listening on medium audio levels in my livingroom.
Please be aware that my speakers are 4ohm bookshelfs.
If it's suitable i would like to reuse a toroid transformer 2x40V big enough.
Old 13th March 2012, 03:50 PM   #273
R.I.P.
40Vac+40Vac is going to give +-58Vdc, or more, for the supply rails.
Expect ~300W into 4r0 from that, requiring a 600VA to 1200VA transformer to power a stereo amplifier.
regards Andrew T.
Old 13th March 2012, 05:11 PM   #274
dirkwright's Avatar
I couldn't find dimensions for the boards on the website. Can you provide them please? I can wait I suppose until they arrive, but I'd like to start planning before then.
Old 14th March 2012, 10:18 AM   #275
R.I.P.
wait till you have a working and tested assembly laid out before you.
Then work out how to package all those modules and build/buy a chassis to suit.
regards Andrew T.
Old 28th August 2012, 03:58 PM   #276
dirkwright's Avatar
How is the performance into 4 ohms? I don't see any data on that.
Also, how many ThermalTrak output devices do I have to buy to get a matched pair?
Old 28th August 2012, 03:59 PM   #277
dirkwright's Avatar
No, all I need are the boards, the transformer, and the big capacitors and I have enough information to decide on the box size.
Old 28th August 2012, 06:16 PM   #278
klewis is offline klewis  United States
klewis's Avatar
You probably won't come up with a matched pair. Just adjust the Re resistors to get a reasonable balance between the p and n.
Old 28th August 2012, 06:47 PM   #279
jackinnj is offline jackinnj  United States
jackinnj's Avatar
I have matched pairs of ThermalTraks on my webstore
Old 28th August 2012, 06:58 PM   #280
dirkwright's Avatar
I don't see NJL3281 and NJL1302 on your site.
Compact Sized LME49810/11 +ThermalTrak AmpHide this!Advertise here!
On Semi ThermalTrak davidallancole Solid State 639 1st May 2013 02:29 AM
LME49810 plus ThermalTrak single-board layout panson_hk Chip Amps 1 28th September 2009 10:57 AM
LME49810 W/ Thermaltrak CFP Output BarryJF02 Chip Amps 6 13th September 2009 12:23 AM
OnSemi ThermalTrak Arius Solid State 8 26th August 2005 04:09 PM
In search for a compact sized motorized pot yairf Parts 1 19th October 2004 02:56 PM
