| Chip Amps Amplifiers based on integrated circuits |
#251 | |
I prefer ThermalTrak since it is more flexible for bias arrangement. STD got the diode connected to its base terminal which limits the flexibility. For 49810/30, if driver is not wanted, we can simply short the corresponding B-E pads and not populate the driver emitter resistor. To my experience with the LME498xx so far, I don't see any obstacle to get decent performance with external driver. Cheers, Panson Last edited by panson_hk; 21st October 2011 at 01:20 AM. |
#253 | |
If you want to do it right, you must use a dedicated driver and a dedicated output device. Try estimating the the current gain of combined driver and output where the designer has control of all the component values. Do this over a wide range of output currents, say10mA to 10,000mA. Try doing a similar current gain prediction for an integrated Darlington using the Manufacturer's datasheet. Integrated Darlington is penny pinching in exchange for quality of performance.
regards Andrew T. |
#254 |
thanks for responding my questions, @panson ok,I think you are right, but for me highend is regulated LME and drivers - so I would be happy :-))) May be your highend quad output amp has regulation on board? @AndrewT I agree, but going the way with drivers adds some more unwanted complexity. For explanation : here we do DIY ! anybody is building his own stuff - very good in my opinion! But outside there are "millions" of +/- identically circuits.... . I don't want to add the next similar circuit to my HIFIcrap. Therefore I don't join GB "The Wire Amp" by opc - also unregulated LME. Means : if adding regulation to LME - you also had to add regulation to the drivers. Who's building his own stuff - and is able to hear - needs not more than max.20s to prefer a circuit with regulated input circuit and (if build in) regulated drivers. I tried this several times. Will say unregulated output stage is ok, all other power sucking crap had to be regulated - you might call this my "highend statement" :-) Engineers mostly may retort this will not spice... yes, may be,does not. But they are all not able to hear, they are fixed on their superduper measurements! For them hearing and comparing isn't worth while. Not cost effective! Other people are hearing with plastic dome tweeters and 17cm bass/mid speaker in bassreflex cabinet. Discussion about deepest bass lines or finest treble resolution is like to explain a blind man colours. I tried this - without any results - on HighEnd-Exhibition in Munich..... what a funny experience - hahahahahaha ;-(((( highend - hahahahaha. Regards Harry |
#255 |
Sometimes a square peg fits a round hole just fine
my guess its you did not actually read even the first page of the thread properly, or just read enough to form prejudicial opinion and moved on.
'the wire' has regulated input stage set to 10v higher than outputs. before you go running your mouth its probably best to know what you are talking about. the (rather good) numbers on the initial amp prototype were unregulated, with single ended inputs and on breadboard but the idea is and has always been to run regulated psu for the front end, with the option to run unregulated if you want. we are also looking at the possibility of quality smps with regulated input AND output |
#256 |
#257 |
An outstanding design once again Panson.
I look forward to your kit!
Mark |
#258 |
#259 |
@qusp thank you for personal adressed "compliment". Do you think this is gentlemen-like? Anyway........... I read "Wire Amp" thread carefully. see post1 schematic : circuit is shown with 3 active elements = LME + 2xMosfets, nothing else. Discussion runs about regulated supply, not about regulation on board with LME. Do you think regulation far away from consumer LME, elswhere in the amp-case, is a good choice? There is only one technical solution that fits for best regulation : minimum space to consumer(LME). Regulated supplies may be good enough for pre-regulation, do you see any regulation near by LME on pcb? NO,.........no regulation on board. Compliment back to sender Regards Harry |
#260 |
Hi Panson,
first of all I'd like to thank you for your well documented and well engineered designs. That's quite a massive effort. I'm also impressed how good your PCBs look. Perhaps there's still some room for improvements. When I took a look at roenders PCB layout for his RMI-FC100 amplifier, I thought, that the layout could hardly be done any better. I especially like the idea to incorporate some massive supply capacitors and some low esr capacitors right at the power devices. I'm not sure, if the local capacitors at the outputs should be grounded as in his layout or better be connected directly to supply capacitor GND, but i'm no expert in grounding. Anyways, I think two big cans somewhere around 4,7-10mF and two 1000uF caps at the outputs could be a nice upgrade to your LME-Amp. Please consider this just as a remark on your highly appreciated work. Thank you. |
| On Semi ThermalTrak | davidallancole | Solid State | 638 | 18th March 2012 06:27 PM |
| LME49810 plus ThermalTrak single-board layout | panson_hk | Chip Amps | 1 | 28th September 2009 10:57 AM |
| LME49810 W/ Thermaltrak CFP Output | BarryJF02 | Chip Amps | 6 | 13th September 2009 12:23 AM |
| OnSemi ThermalTrak | Arius | Solid State | 8 | 26th August 2005 04:09 PM |
| In search for a compact sized motorized pot | yairf | Parts | 1 | 19th October 2004 02:56 PM |
| Page generated in 0.12769 seconds (80.95% PHP - 19.05% MySQL) with 11 queries |
