| Chip Amps Amplifiers based on integrated circuits |
#211 |
Perfect, as the 0.1uF is a Vishay MKT 1822 400V and the E-Cap is a Nichicon YXA 63V 100uF
#212 |
Here is a plot for comparing THD of a 470 uF e-cap with and without a 0.1 film cap in parallel. The THD of the film alone is also shown. The curves associated with the 470 uF e-cap do represent the residual distortion of my AP. It meas that no additional distortion can be measured for the e-cap.
Well, do we really need to parallel a film cap with the e-cap in NFB path. Yes, we can since it does nothing wrong objectively. It may make subjective differences. I don't know for sure. However, it does make some people feeling better who believe e-cap must be bypass by a film cap for better high-freq characteristic. This is true in certain applications, but not universal. Simply copy and paste does not engineering. Last edited by panson_hk; 13th August 2010 at 03:24 AM. |
#213 |
i dont see plot....
#215 |
Even though picture quality is poor, there is a slight difference.
the film doesnt seem to handle lower frequencies too well, yet the electrolitic does a good job at "dampening" that. These 2 caps seem to compliment each other, where one makes up for the shortcoming of the other one. |
#217 |
to avoid using any e-cap in the NFB path, JLH used a pair of 4.7uF film caps in parallel and adjusted the NFB resistors up in value to bring back some bass response.
He did this even though the very high resistor values would increase amplifier noise slightly because he thought the sound quality improvement brought about by the no e-cap solution was a better compromise than reducing noise.
regards Andrew T. |
#218 | |
http://archive.chipcenter.com/eexper...kruger007.html |
#219 |
but only for decoupling and particularly good for decoupling VHF. This is where they perform very well, in digital circuit with their very fast ON/OFF/ON/OFF going into the Gswitches/second.
regards Andrew T. |
#220 |
I am working on a new layout for 3-lead power devices. KiCad is employed for the new board. Here is the schematic. Compared to the previous version, the following items are added.
Any comment is welcome. Last edited by panson_hk; 6th September 2010 at 08:04 AM. |
| On Semi ThermalTrak | davidallancole | Solid State | 630 | 11th August 2010 05:26 PM |
| LME49810 plus ThermalTrak single-board layout | panson_hk | Chip Amps | 1 | 28th September 2009 11:57 AM |
| LME49810 W/ Thermaltrak CFP Output | BarryJF02 | Chip Amps | 6 | 13th September 2009 01:23 AM |
| OnSemi ThermalTrak | Arius | Solid State | 8 | 26th August 2005 05:09 PM |
| In search for a compact sized motorized pot | yairf | Parts | 1 | 19th October 2004 03:56 PM |
| Page generated in 0.13263 seconds (76.90% PHP - 23.10% MySQL) with 11 queries |
