| Chip Amps Amplifiers based on integrated circuits |
Hi all
I have a completed BrianGT LM1875 PCB and PSU however, I consistently measure the supply voltage on the output (25v). I suspect I may have a fried chip but I have assembled the board and psu using standard components and have checked many times. Can anyone point me in the right direction why I might be getting this short on the output? Thank-you |
#2 |
Update: As read somewhere, I added a 47kohm resistor R6 between input and output ground. This seems to have stopped the supply voltage appearing on the output, but now there is NO output at all. What is the correct resistor to use or is a jumper all that is needed???
Thanks |
#3 |
A jumper is usually all that is needed. The resistor comes into play, if you have hum. Sometimes you can cure that with a small resistor, below 10 Ohms.
With a 47k resistor in that position you set the gain to 1, so you have no voltage amplification at all. Usually full rail voltage at the output indicates a fried output transistor. Desolder the IC and measure with an Ohm-meter from pin 3 to 4, then from 4 to 3, then from 5 to 4, then from 4 to 5. If you have continuity in more than two of the cases, you need a new LM1875.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
| Amplifier theoratical max rated output power based on supply voltage | wwenze | Solid State | 13 | 26th September 2009 05:02 PM |
| Diodes on power supply output for voltage drop? | bst | Tubes / Valves | 7 | 12th July 2007 03:54 PM |
| supply rail voltage on 3875 output ? | Buhl | Chip Amps | 10 | 9th November 2006 09:44 AM |
| Sonic impact t amp - supply voltage on the output of one channel | deiksac | Class D | 6 | 7th April 2006 10:07 AM |
| tailor output voltage of power supply | Evaas | Solid State | 15 | 28th April 2001 06:55 PM |
| Page generated in 0.10368 seconds (71.57% PHP - 28.43% MySQL) with 10 queries |
