Old 9th October 2009, 03:56 AM   #1
raypalmer's Avatar
Default BrianGT 3886 Monoblocks too quiet!
Well I've got them built and working properly but for the fact that they output far, far, far too quietly
What's the most common cause of this?
Wherever you go there you are.
Old 9th October 2009, 04:23 AM   #2
MJL21193's Avatar
Incorrect gain maybe, check resistor values.
Not enough input signal voltage - what is the source?
Old 9th October 2009, 11:26 AM   #3
Could the mute be enabled? That would be about whisper quiet.
Tyler
Old 9th October 2009, 12:14 PM   #4
Ted205 is offline Ted205  United Kingdom
Ted205's Avatar
have you checked the gain with a scope ?
Old 9th October 2009, 12:26 PM   #5
just another
wintermute's Avatar
I think this is a good suggestion. There should be a resistor between V- and pin 8 to disable the mute. It is not a case of the switch connects the v- via said resistor to mute the circuit, the circuit is muted by removing the voltage on pin 8. So if you thought you didn't need a mute circuit and left it out then that is probably the problem
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 9th October 2009, 01:03 PM   #6
it's a Brian GT PCB. It should have all the necessary components on it.
But does it?
Where is the link to the required checking info?
regards Andrew T.
Old 9th October 2009, 04:52 PM   #7
raypalmer's Avatar
Double checked the five resistors on the board check out....
I'm using a passive pre amp...
Old 9th October 2009, 04:56 PM   #8
Puffin is offline Puffin  United Kingdom
If you have difficulty reading the bands on the resistors, the easiest way is to check their values with a multimeter.
Old 9th October 2009, 05:31 PM   #9
Electrons are yellow and more is better!
peranders's Avatar
Try to exclude it and connect directly to you signal source.
/Per-Anders (my first name) or P-A as my friends call me
Old 9th October 2009, 09:52 PM   #10
raypalmer's Avatar
Okay so directly off my TV it's loud as heck.
But my passive works great with my LM3875? Is there such a huge gain difference??
How quiet is dead quiet? pchw Tubes / Valves 36 22nd November 2007 04:36 AM
BrianGT 3886, remote pre and chassis for sale troystg Swap Meet 25 13th March 2007 09:57 PM
BrianGT's 3886 kit, a little help required.. MrSensitive Chip Amps 2 16th August 2005 01:08 PM
transformer with 3886 (BrianGT Boards) mantisory Chip Amps 2 3rd May 2005 02:59 PM
Impressions of Snubbered BrianGT 3886 vs Reg 3886 moving_electron Chip Amps 1 23rd March 2005 06:51 AM
Page generated in 0.09373 seconds (80.13% PHP - 19.87% MySQL) with 10 queries
