Old 6th October 2009, 07:01 AM   #1
Default Tda7294 dc volt
hI,
I am building a TDA7294 AMP. Help me on DC volt limit. I have a 35 0 35 rail and after regulated it gives +47 0 -47 v. May I use it for 7294??
Thx
Old 6th October 2009, 09:48 AM   #2
Hi!
In practise, I would not go to the maximum limits of a TDA7294. For a stable operation, I would recommend a transformer with 22-0-22 V rails for both 8 ohm and 4 ohm loads, and perhaps 25-0-25 V (up to a mximum of 30-0-30 V) for 8 ohm speakers only.
But that's quite allright. I build amps using TDA7294 and TDA7293 and these chips do perform very well with a 22-0-22 V transformer (around +-30V after rectification and smoothing caps).
Regards - martin
Old 6th October 2009, 11:15 AM   #3
sangram is offline sangram  India
No.
The TDA7294 cannot operate safely with such high rails, it is specified for maximum operating voltage of 40V in high-efficiency mode or 35V in Class AB (normal) mode.
Since you have a regulated supply, I would advise you reconfigure the regulators to 35V rails. This should be relatively simple.
Old 7th October 2009, 12:12 AM   #4
Minion is offline Minion  Canada
Ive got a TDA7293 running off of +/-42v DC and it runs fine but I believe it is the upper limit that the chip should be run at , I"m running my next Stereo TDA7294 off of +/-34v DC .....
CHeers
Old 8th October 2009, 06:12 AM   #5
kroto is offline kroto  Indonesia
kroto's Avatar
Send a message via Yahoo to kroto
I want to build TDA7293, how to use the Clip detector with LED? just simply add a resistor and LED?
for mute and standby function, should it be powered from external supply(low voltage) or connect it from the +Ve main power?
Old 8th October 2009, 08:43 AM   #6
For safe operation I changed the rail as per the advice and it works fine now with 25 0 25 rail. Sounds good.
If anybody have a nice mosfet or transistor circuit which is very stable with 35 0 35 rail (DC RANGE OF 50 V).. I want to build a subwoofer amp..
thx..
Old 13th October 2009, 01:45 PM   #7
My TDA7293 have +/-35V rails without any problem and the St.By/Mute is connected to +35V.
If you dont want a plastic box TV sound (Schematic in data is made for that use) :
replace the 22uF between 680 Ohm and ground by a jump and increase the 22uF bootstrap cap to a good 220uFcap (Elna Silmic)
Philippe
Old 19th October 2009, 10:10 PM   #8
Default Tda7293 and TDA7294
Originally Posted by prabanjas View Post
hI,
Thx
Hi,there somwhere!
I have over 7 years built amps with these chips and my suggestion is to use power supply with not over 34 volts per rail.For bridge application i used phase-turner with opamps and the power i got was higher than with manufacturers suggestion (see the datasheet,it`s not good solution).With +/-
34 volts power supply (+15000 mkf ellytes per rail) i `ve got starting limiting sinus at 32 volts rms on 8 ohms.Remember that 0,1-0,5 mkf capasitors on power supply are needed as near as possible to chip to avoid self-oscillating and for low thd.Heatsink i use is allways with bigger surface area than suggested and allways with automaticaly powered ventilator.Never burned
any chip.And allways satisfied with sound.
Hannes from Estonia..
Old 2nd June 2010, 05:35 AM   #9
guaxian is offline guaxian  China
Send a message via Yahoo to guaxian
HOW ABOUT AC 30V?
+-42V is dangerous for TDA7294?
Old 2nd June 2010, 10:35 PM   #10
dh
Tda7294 e_fortier Chip Amps 2 27th November 2008 01:33 PM
TDA7294. . . help! ;) danielwritesbac Chip Amps 3 19th April 2008 06:58 AM
Switching 230 Volt Transformer to 120 Volt OMNIFEX Parts 10 6th April 2008 04:34 PM
My TDA7294 Amp panson_hk Chip Amps 1 27th June 2007 01:06 PM
Tda7294 Angel Puerto Chip Amps 6 21st August 2003 02:08 PM
Page generated in 0.09715 seconds (80.11% PHP - 19.89% MySQL) with 10 queries
