Old 2nd October 2009, 01:06 PM   #1
sasmit is offline sasmit  India
Send a message via Yahoo to sasmit
Default LME 49810 CFP output stage
I am trying to design an amp based on the complementary feedback pair concept, although this a slight deviation from the original CFP concept because of the extra transistors in the output stage. The schematic shows 3055 and 2955 in the output stage but the reason they are there is eagle only had these with package outline matching my requirements. I intend to use some sustained beta devices.
There are quite a few 49810 designs out there but all of them are Emitter Follower types...I might have goofed up here....any feedback will be highly appreciated..
Old 2nd October 2009, 01:23 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
Just wondering, why do you want this topology? A potential problem may be that this power stage has gain involved => problems with the phase characteristics.
/Per-Anders (my first name) or P-A as my friends call me
Old 2nd October 2009, 01:42 PM   #3
ya..that is one of the charateristics of a cfp stage to have some ammount of gain..but is superior to an emiiter follower design in terms of Large signal linearity and distortion figures. This design is very simmilar to one found on rod elliot P3 amp. I did some reading and it seems thermal stability is better than an EF type besides "beta droop" is lower than an EF type.
Old 6th October 2009, 07:45 AM   #4
panson_hk's Avatar
All my 498xx are EF outputs. Looking forward to see your results.
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
preamp output stage resistor from output to V- ? ? Bernhard Solid State 4 19th October 2007 02:55 PM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
TV Horzontal Output Transistor for output stage..? ronybc Solid State 46 10th October 2005 02:26 AM
Page generated in 0.06939 seconds (69.68% PHP - 30.32% MySQL) with 11 queries
