Hey guys, I am looking forward to building a powerful and portable amplifier that can fit into a back pack, and run off a single 12V 7ah battery. I have the speakers sorted out already, their impedance is 8ohm and have a power limit of 100W.
So I am looking for a simple chip amp that can provide an output of 20W - 40W into these speakers. I looked at TDA1560 but I could not obtain them, is there any other similar chips or designs I can use.
Thanks in advance.
Thanks in advance.
Thank you very much, i had a look at the data sheet of tpa3122D2, it should work just fine for my application. but I have one more question the maximum gain of the chip is 36dB, so can it be powered straight off something like a mobile phone or an iPod's audio output, or does it need a preamplifier to reach maximum output.
Would this circuit work?
It is has two op amp working as a crossover network at 4000Hz, the treble goes to a ready made TEA2025 amplifier and 2 8Ohm mid range speakers.
The other two op amp change the single ended low frequency signal into a balanced and inverted signal which passes through one of those 2 in one potentiometer and goes into the TPA3122 input.
I am a newbie in electronics, especially the audio part so any help is appreciated.
Here's a friend's design based on that chip:
http://ecorenovator.org/forum/appliances-gadgets/358-amanda-harris-prius-home-audio.html
Just replace the power supply with the battery. Power output will be limited at 12v, but it may still be plenty. If not, use a DC/DC converter to increase the voltage or use two 12v batteries in series.
