Help me identify the following please
Old 29th September 2009, 06:57 AM   #1
bail_w is offline bail_w  United States
Default Help me identify the following please
Can someone help me identify which of the following is the tip, ring, and ground?
http://www.diyaudio.com/forums/attac...8&d=1195243855
I removed the gold sleeves or should i not?
Old 29th September 2009, 07:42 AM   #2
Here is the picture without removing the gold sleeves.
Old 29th September 2009, 07:48 AM   #3
jaycee is offline jaycee  United Kingdom
by "gold sleeve" i assume you mean the grounding braid around the two inner cables. This braid is connected to ground. To find out where the other two wires connect, use a multimeter with a resistance or continuity tester to find out.
Old 29th September 2009, 11:23 AM   #4
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Hi Bail_w as Jaycee says a multimeter on continuity (or even low ohms) is the best way to identify the wires. From the looks of the pdf you attached to, this is for connecting to a subwoofer? As the stereo is not important for a subwoofer, I'd suspect that the only "important" connection is the ground which is the sheild (ie non-insulated third wire). If it is a mono sub, it should not matter whether left is connected to left and right is connected to right... the ground is the important wire, the other two can probably be interchanged without any problem.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 29th September 2009, 04:40 PM   #5
Okay, thank you for the replies.
I have another question, in the pdf file, the direction was for one single stereo jack (the OP only want to use it with Ipod). Right now, i want to make use all three stereo jacks, so i am lost on how to connect all three of them.
Help me identify the following pleaseHide this!Advertise here!
Can you identify this cap? Richidoo Parts 4 13th March 2009 11:53 PM
Please, can someone help me identify these ? juma Multi-Way 5 11th April 2008 08:14 AM
Please help identify this amp kijana Everything Else 5 13th November 2006 09:53 PM
Help me identify this? peace brainerd Solid State 11 3rd August 2006 05:22 PM
Help identify value of cap mouse Parts 3 8th November 2003 11:22 PM
Copyright ©1999-2017 diyAudio
