Old 6th November 2009, 12:07 PM   #91
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I have not read the entire thread, but if you are discussing how to get chip-amp "simplicity" at higher powers (more than +/-40V rails and +/-10A output), class D is the way to go.
What star882 is trying to explain is that with two TO-220 output MOSFET, a driver IC, a comparator IC, the LC output filter and some more parts you can get close to 1KW at 4 ohm (+/-90V rails). No bulky heatsinks, no heavy power supplies (class AB wastes more power than what it delivers to the speakers), no dozens of expensive output devices and the chore of mounting them.
Incidentally, all my amplifiers are either chip amps or class D. I don't keep any of my class AB discrete prototypes, they use too many parts for what they achieve.
I use to feel like the small child in The Emperor's New Clothes tale
Old 6th November 2009, 12:48 PM   #92
Eva's Avatar
Originally Posted by AndrewT View Post
which chipamp are you recommending that has these MOSFETs or IGBTs integrated into them?
Above 100V and 10A you can't expect the output devices t come in the same package as the small signal stuff, the fabrication processes are quite different. Also, PCB layout and thermal considerations and package parasitics prevent everything to be in the same chip.
For example take a look at IRS2092:
http://www.irf.com/product-info/data...ta/irs2092.pdf
It contains a simple class D modulator, rudimentary current limiting and gate drivers, it only requires an output stage and a LC filter. It can be considered a high power class D chip amp.
Old 6th November 2009, 06:02 PM   #93
danielwritesbac's Avatar
Originally Posted by Eva View Post
. . . class AB wastes more power than what it delivers to the speakers. . .
That happens at three configurations.
1), like the gainclone, large caps locally, is a bit like driving the car in one gear too low. For the amp, its a way to level the frequency response--technically an inappropriate method, but it does work. There are other ways to change the speed: HDOA - High Dynamics Op Amp
2), the "fireball" amp (not a gainclone type) operates as a dynamics expander for a more-live presentation--Class D will emit a great deal of green smoke instead (unless the voltage is decreased).
3), over-reliance on noise filtering at the amplifier board instead of using noise filtering at the power supply--the great tolerances of Class AB are often exploited to decrease power circuit expense at the cost of efficiency, wheras, the smaller tolerances of Class D usually force one to do a good job on the power circuit design.
I really do like the sound of Class D. The chopped signal reminds me of Blackgate or the classic Red Cerafine+Polyester combo. This can make a lovely clarity. Unfortunately, the supersonic pilot tone of Class D is audible to me. After many hours of exposure, I get stuffy ears and it takes about 3 days to recover. One day, I'll explore using Class D in an active 3-way system for bass and midrange.
Its possible for the efficiency of Class AB to match Class D at scales up to 70 watts (run the same little TO220 size heatsink nearly cold), but I don't have personal experience with comparisons beyond that point, so I couldn't tell you about efficiencies on a larger scale amplifier.
Old 6th November 2009, 06:31 PM   #94
Eva's Avatar
I design class D amplifiers for a living, now I'm working in a commercial product with nearly 400 parts in it, smaller than a shoe box and capable of over 4kw on 2 ohms, and I admit that I fail completely to understand what you are talking about.
So sorry for disturbing if you were talking about metaphysics, I thought it was about electronics and acoustics (science)
Old 7th November 2009, 11:56 AM   #95
Do you also include audiology? If so, that would be impressively efficient.
Old 11th November 2009, 12:40 PM   #96
authlxl is offline authlxl  China
SINEWAVE ELECTRONICS CO.,LTD
Send a message via MSN to authlxl
Default Please lokk here!
Originally Posted by Mark Allen View Post
Is there a design here for a high power Chip Amp? Say three or four chips in parallel. The single chip amps just doesn't quite cut it for me or my Dynaudios... I have seen several from Asia on E-Bay but am extremely hesitant to order from China because of all the rights infringement going on over there.
Thanks for any suggestions,
Mark
Look here
Class D Audio, Who are these guys?
High Power Chip-based Amplifier? deiksac Chip Amps 6 24th October 2006 01:30 PM
Another high end hybred chip amp? teknofossil Chip Amps 4 28th April 2005 10:36 PM
"BPA 400"? Other high power chip amps? AAXenoStrange Chip Amps 5 17th February 2005 05:57 PM
Need high power sub chip amp . darkm4n Chip Amps 5 15th September 2004 07:18 PM
Page generated in 0.10032 seconds (79.18% PHP - 20.82% MySQL) with 10 queries
