| Chip Amps Amplifiers based on integrated circuits |
My z-680s seem to have taken their last breath. After stretching their legs with some good bass, the system shut off. I replaced the blown fuse with a new slow blow fuse and was greeted with a short (.5 second) hum and some sparks and smoke. What most likely failed, and can I repair it?
#2 |
It appears that 2 of my transistors exploded...
#3 |
That is not a transistor. It is a TDA7293 chipamp.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#4 |
#5 |
Just bought two TDA7293s off ebay. I guess I will replace the blown ones and see what happens?
#6 |
It is highly unlikely that the TDA 7293 blew by itself..so before you put these new ones back in....please check the power supply and other psu components on the board...something is seriously wrong with them.
#7 |
well I know in the logitechs, two of the chipamps are bridged for the sub.. Now I don't know how to tell which ones are bridged or not, or if that even matters.... And are there any newb diys sitting around for how to check my power supply? I have my multimeter here... But pretty clueless.
#8 |
are there any components of my power supply in particular that I should be looking at?
#9 |
So upon further disassembly, it appears that the sub is blown, sounds like the voice coil is destroyed. So Now I am going to have 7 TDA7293s and some of the other good parts from this amp... so who wants to help me build my first amp? Looking at the chip amps everyone here has built, has got me inspired.
#10 |
The PCB looks damaged - those blackened traces and also it appears there is a charred area under the chip. The components near those traces have almost certainly fried.
Furthermore, it is likely that the subwoofer speaker's voice coil has also fried (probably what fried the chipamps). Push the cone of the speaker in and out. If it is not smooth, and feels like it grates, the voice coil is fried. Where did that large blob of solder come from? I'm afraid I couldn't recommend attempting repair - the damage looks too great. |
| Logitech Z-680 | soundNERD | Chip Amps | 62 | 15th March 2009 09:35 PM |
| New display for a logitech h. 525 | MammaMumin | Everything Else | 0 | 30th December 2008 10:05 PM |
| Logitech Z-680 | B-EAGLE | Parts | 0 | 8th August 2008 06:10 AM |
| logitech z-680 repair | Catfish45 | Everything Else | 1 | 7th July 2008 05:40 PM |
| logitech x-140 | raindog | Multi-Way | 3 | 17th April 2008 01:41 PM |
| Page generated in 0.10113 seconds (80.61% PHP - 19.39% MySQL) with 11 queries |
