| Chip Amps Amplifiers based on integrated circuits |
#21 |
I posted a spreadsheet that will simulate a linear power supply with the worst-case load, with variable transformer ratings, reservoir capacitance, load resistance, rated output power, and basically everything else you need, which is attached to the post at:
Power Supply Resevoir Size It uses a numerical solution of the differential equations for the circuit. So no approximations are used. A downloadable PDF file describing the spreadsheet, and the solution method, et al, is attached to the post at: Power Supply Resevoir Size However, I recommend using LT-Spice, since it is much more flexible and powerful. It is a free download from linear.com. Cheers, Tom Last edited by gootee; 10th February 2013 at 05:09 AM. |
#22 |
#23 |
Question to you guru's if I may.
On the website of TI they show an SMD version of the LM3886, see pic. But none of the usual suspects have them in their catalog. Anyone seen one of those, or know where to get them? tia, jan
/Yes! Its out: Linear Audio Vol 5! I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun |
#24 |
Probably custom order by the 1000's for Manufacturers.
#25 |
If they don't offer samples, can you simply make some by bending the pins of a through-hole version into the correct positions? Or do you need some "real ones"?
#26 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Datasheet only lists two types of package and neither is SMT, must be marketing vapourware or special order only.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#27 |
Yeah could be. I fired off an inquiry to TI.
Let's see what they say. Maybe they are just testing the waters. jan
#28 |
What do you need it for?
| MTM - Stage 2 - Finalizing XO before build and need HELP :) | thunk303 | Multi-Way | 39 | 13th September 2009 06:42 AM |
| LM3886, TDA2050 etc., P2P or PCB | pra3718 | Chip Amps | 9 | 9th September 2009 03:03 PM |
| TDA2050 vs LM3886 | Wynand | Chip Amps | 5 | 7th September 2009 05:49 AM |
| Finalizing FR125 configuration | Voodoo Rufus | Full Range | 32 | 19th June 2006 08:40 PM |
| Finalizing box volume for SS8565-01s, does this look about right ? | Jean | Multi-Way | 14 | 3rd May 2003 03:28 AM |
