Old 18th September 2009, 08:41 PM   #1
Exclamation Opamp capable of driving low z load.
HI! I'm currently building a headphone amp using NE5532's. They drive my 32ohm phones quite ok....
I was wondering if anyone knows of an opamp that can deliver a bit more drive to my phones.
Any help will be appreciated.
Old 18th September 2009, 11:34 PM   #2
mctylr is offline mctylr  Canada
While there are op-amps (and buffers such as video buffers from TI, Analog, etc.) that have higher power handling, you could also go with a single push-pull transistor power amplifier after the op-amp's output. Some exaples would be Analog's BUF03/BUF04 which are obsolete, AD811, AD817, OPA633, LT1010.
See: <http://waltjung.org/PDFs/WTnT_Op_Amp_Audio_1.pdf>.
Transistors for power stage amplification include, but are not limited to, 2N5089/5088, 2N4124/4126, MJE170/MJE180, BC556B/546B, or BD139/140 for NPN/PNP pair.
Hope that is useful for you.
Old 20th September 2009, 10:04 AM   #3
veteran is offline veteran  Poland
veteran's Avatar
You can also use OPA552 or LME49610 buffer for low impedance headphones.
Simple audio solutions
blog.unisonus.com
Old 20th September 2009, 11:38 AM   #4
particularly the series he compiled on composite opamps.
regards Andrew T.
Old 20th September 2009, 12:42 PM   #5
5th element's Avatar
There's always the TPA6120
http://focus.ti.com/lit/ds/symlink/tpa6120a2.pdf
But I wouldn't want to use it without a good PCB.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 20th September 2009, 01:02 PM   #6
Impressive specification.
Does fig34 demand a ground plane? Or can a very short ground trace remove the risk of oscillation? If so then how does this need to engineered?
regards Andrew T.
Old 20th September 2009, 01:53 PM   #7
jackinnj's Avatar
There's a Head-FI thread on the TPA6102. http://www.head-fi.org/forums/f6/my-...pa6120-274337/
I know this is anathema to the group -- but there's an evaluation board for $50! (They save you so much work, and you can see how the folks at TI got it to work without singing!). $50 is less than it would cost to get the parts together and have a PCB done by expresspcb.com.
Old 21st September 2009, 12:35 AM   #8
jcx is online now jcx  United States
I've built a multiloop prototype with LT1210 30 MHz 1A cfa output in TO-220 on a clearance hole gnd plane perfboard with apparent success ("tombstone" ceramic smt caps to the power leads)
high speed prototyping is possible but tedious - usually I don't find the energy to make a second channel
http://www.linear.com/pc/downloadDoc...28,P1219,D4138
a 'scope with a few times higher bandwidth than the fastest part is real helpful
Old 21st September 2009, 09:18 AM   #9
Thanks! this is surely a gr8 help.!!
Old 21st September 2009, 12:50 PM   #10
I see what you mean, it does imply that it could work without a ground plane - after all you do remove the copper beneath the input and output pins as it is. The only thing left is the powerpad.
$50? The price quoted by TI is $99, either way you can just look at the PCB design in the evaluation modules datasheet -
http://focus.ti.com/lit/ug/slou169/slou169.pdf
where you can indeed see that most of the ground plane around the chip has been removed.
minimum load impedance for DIY opamp F1 FAN Pass Labs 2 15th September 2009 02:21 AM
high power amp capable of driving 2ohms elviukai Solid State 2 4th August 2008 05:55 AM
Dynamic load line analysis using music and speaker load Michael Koster Tubes / Valves 0 7th March 2008 08:47 PM
LM4780 Capable of driving Martin Logan Ascent i's??HELP?? Dominick22 Chip Amps 29 21st January 2006 10:37 PM
opamp driving tubes skyraider Tubes / Valves 61 29th April 2005 06:57 AM
Page generated in 0.11425 seconds (76.86% PHP - 23.14% MySQL) with 11 queries
