| Chip Amps Amplifiers based on integrated circuits |
Just a quick question on GC's and zobel networks. I have an Audiosector LM3875 GC, running in dual mono configuration, driving 8 ohm speakers. I would like to try out a Zobel network, mainly for peace of mind. I was wondering what the stock values are (or should be) for R and C, and what type of capacitor is the best to use? Chris. |
#2 |
hello.
often used r=2,7 ohm , c=100 nf /100v or more greetings |
#3 |
0.1uF/2.7ohm? What effect will these values have on the sound, and will a ceramic capacitor (I have some 0.1uF Kemet's in my spares box) be Ok in this application?
Regards, Chris. |
#4 |
Yes, those are correct values, and they also have been specified here: http://audiosector.com/lm4780%20amp.pdf
Use metalized film cap, similar to this: http://search.digikey.com/scripts/Dk...name=BC2054-ND
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#5 |
Thanks Peter.
Chris. |
#6 |
Those parts will add coloration to the sound, I never tried ceramic in this application, so can't comment, but generally film would be better.
#7 |
#8 |
As well as giving me peace of mind, I am hoping the zobel network will solve a minor issue I have. Occasionally I get interference (using FM receiver) which causes a humming noise at the speakers. This noise remains present even after the source attenuator (50k Alps blue, dual log with a 47k metal film shunt) is turned down to minimum, i.e. input shorted to earth.
Chris. |
#9 |
It could be Zobel, or maybe you need this mod: http://www.diyaudio.com/forums/showp...2&postcount=51
#10 | |
| zobel question | sakis | Solid State | 11 | 26th September 2008 08:51 AM |
| zobel question? | fazman | Multi-Way | 2 | 18th December 2005 04:11 AM |
| Zobel Question | poeee | Chip Amps | 2 | 5th January 2005 05:29 PM |
| zobel question | soundNERD | Chip Amps | 17 | 10th November 2004 07:05 AM |
| Zobel question | soundNERD | Chip Amps | 12 | 29th March 2004 11:57 AM |
| Page generated in 0.09397 seconds (80.07% PHP - 19.93% MySQL) with 10 queries |
