Mini Water Cooled GainClone?
Old 17th May 2003, 01:07 AM   #21
Music Machine is offline Music Machine
Cut the heat sink in half. If it's water cooled it should be more than big enough. That would make the whole thing smaller too.
Old 17th May 2003, 01:09 AM   #22
SkinnyBoy is offline SkinnyBoy  Australia
Banned
Send a message via MSN to SkinnyBoy
That might work.... except the square pad in the middle is only 2cm X 2cm... the perfect size for mounting an LM38** amplifier IC on....
Old 17th May 2003, 03:51 AM   #23
Banned
Do I need the filter caps in the box? or can they be mounted in the powersupply box? or, does that sorta defeat the whole purpose.?
Old 20th May 2003, 01:54 PM   #24
carlosfm is offline carlosfm  Portugal
Banned
You need the filter caps in the box, near the chip supply pins, or you'll have serious oscillation problems.
But then again, when you've done drawn everything in a can of varnish, two or three times.
Seriously.
With everything isolated, no problem.
But when you power it inside the water, please stay away.
Something can be deadly wrong.
lol
Old 20th May 2003, 05:19 PM   #25
Sawzall is offline Sawzall
Default just make a blob
there exists some heatsinking type glues that are based on epoxy that do not conduct. These would be perfect for your use here. Build the circuit point to point as tight as possible, perhaps using tiny heat shrink to make sure the leads remain isolated from each other. In the end you will have 6 leads coming out, twist the mates of each other, then compress into the tinyest space you want, then pot the entire thing with the glue. When you are finished, it will be waterproof. The heat will be carried by the adhesive.
One improvement might be to place the back of the amp chip on an outside edge, and thread an insulated bolt through the hole, and then outside your little form. When you are finished, use the bolt to mount it, even to a heatsink later if you decide to use it out of water.
Old 21st May 2003, 01:52 PM   #26
Banned
Hey Sawzal, what's a blob?
A blow job?
Ok, ok... just joking.
Anyway, there are some silicone types that are transparent and don't conduct.
It micht be a good alternative to water.
I don't like point-to-point, but that's me.
A circuit made on breadboard would do it, and no risks of wires touching each other.
Old 22nd May 2003, 02:54 AM   #27
Banned
A blow job?
It the circuit consists of only 5 components, whats wrogn with point to point? lol
Old 22nd May 2003, 09:32 AM   #28
Banned
Hey SkinnyBoy,
As I said, I don't like it, but that's me.
I don't like to fiddle with wires.
I always make it on breadboard.
lol lol lol lol!!!!
Old 24th May 2003, 02:44 AM   #29
Default well, a blob is
a blob. I am sure some bright person here can tell us how it came into the English language. One thing about English, especially the US version, is that it takes in everything and makes it its own, with some added strangeness. Those few USians who study a language other than English are stunned by it. On the otherhand, if you look at most other languages in the world you will see the effect of US technology in the language - it is the standard for tech it seems (I can see some flames so I will shut up)..
But anyway, the heat sinking ability of those adhesives are important! I don't think plain silicone moves much heat. Its cheap at $5 a little tube.
Old 24th May 2003, 10:37 PM   #30
Fusor is offline Fusor  United States
Fusor's Avatar
May I suggest the gainclone coffee cup warmer?
[blob = old English blobber, a puddle?]
Mini Water Cooled GainClone?Hide this!Advertise here!
water cooled zen amp. firezab Pass Labs 100 23rd September 2009 02:21 PM
Water-cooled Hojvaelde Pass Labs 24 24th May 2007 07:30 PM
hmm water cooled amp karma Everything Else 1 20th August 2003 11:43 PM
Water cooled plate on ebay (possible water cooled amp application) BrianGT Parts 1 27th May 2002 03:19 PM
