Old 14th September 2009, 11:34 PM   #1
longthrow's Avatar
Send a message via MSN to longthrow Send a message via Yahoo to longthrow
Default STK4050V current boost
hi to all,
output loading on stk4050v is limited to 8r0.
loads lower than 8r0 is not recommended...
to increase its output capacity, im planning to add
power transistors on the output stage...
the stk 4050v's internal is quasi and the external power transistors
make the output stage a quasi driving a complementary; partly
similar to triple darlington...
the plan is to modify an existing stk4050v ckt/ckt board so it can
drive lower than 8r0.
need comments/suggestions/recommendations on this ckt:
H V E Audio
Old 15th September 2009, 09:50 AM   #2
You could reduce the rail voltage by ~30 % to make the STK 4 Ohm stable without adding further components.
Adding transistors to the output of a power op amp is not a promising way to achieve a good sounding amplifier. How do you bias the transistors into their optimum operating point? How much will the STK contribute to the output power with that 10 Ohm resistor in series to the sepaker?
You will probably be better off with a solid state amplifier or, if you don't dare to tackle the driver stages, a driver IC, like the LME49810 and transistors.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 16th September 2009, 12:28 PM   #3
metal is online now metal  Jordan
metal's Avatar
This will not work for STK chips.
any way, finally...
Old 24th September 2009, 01:03 PM   #4
Default To Metal and others who can lend a helping hand.:)
Hello Metal... Can I have your email...I have a couple of IC STK4050V with me and I purchased those from china supplier... I guess it's not the original IC from sanyo. Hoping I can have your support coz I'd like to build an amplifier out of this IC. My email is y2kact@yahoo.com. Please refer to attached image for the IC.
Thanks & regards
constant current boost converter djQUAN Power Supplies 5 12th October 2009 09:39 AM
[enquiry] Treble Boost/High frequency Boost circuitry elnino86 Parts 2 18th December 2008 12:33 PM
317/337 with current boost jaudio Power Supplies 2 19th January 2007 06:42 PM
current boost lm317 prob. deepanger Solid State 15 7th October 2004 06:52 AM
Stk4050v steffmeister Chip Amps 1 22nd September 2004 02:56 PM
Page generated in 0.07395 seconds (79.44% PHP - 20.56% MySQL) with 11 queries
