| Chip Amps Amplifiers based on integrated circuits |
Hello,
So here's my situation. I'm taking the plunge. I'm looking for a SIMPLE build that is a very good amplifier (gainclone, chimamp, whatever you call it). I have an option as well. I am building the speakers and they are great candidates for being active. Is there any reason not throw these amps in a bass reflex cabinets (assuming I properly compensate for heat)? Anyway, I am looking for advice on what to build. Obviously I am looking for as simple a build as possible. But like anyone else, I want the best too. It's a small room and the speakers will never be played loud. Nor am I going to have bass thumping and anger my neighbors. So I am looking for suggestions. What design to use, parts, etc.? Like most people, I prefer tube amps. I am not foolish enough to think I can get tube performance for a fraction of the price. But if I could get the liquidity, the 3D soundstage... that would be nice. Anyway, I would appreciate anyone's help. Thanks |
#2 |
There was a thread a while ago that may be of interest to you.
Active ZD5s Hope it helps a little John |
#3 |
Attaching your amps to the back-plates of the speakers would be fine, and you could start with a single amp on each speaker feeding into a conventional cross-over. Later you might decide to split the cross over and use one amp per drive unit.
If you arange your amps (on your speakers) to have balanced (i.e. differential) inputs then you could build a balanced tube preamplifier to drive the lines to the amps. Best of both worlds? |
#4 |
I know the LM3886 is not exactly new, but I've heard examples sound good. Using these amp chips leads to a relatively simple build, so you may wish to consider this option. A Google search for LM3886 will bring stacks of info (, as would using the search facilities of this forum).
#5 | |
Cool thanks everybody!
More than likely the speaker will employ a full range single driver. Makes things very convenient for me. I would go the internal monoblock route. Not sure what I would do about volume control though, my source has no volume control on it. So perhaps I would be forced to use a preamp, even though I only have one source. I had done some searching regarding gainclones and such. But there was just so much out there... I didn't know where to start. Do I buy a kit? Where can I find parts? Where can I find designs? Which chip is best considering my tastes? Etc.. So that's why I came here to ask others to put me on the right path. Is the 3886 my best option? And is there a benefit to the insulated or noninsulated version? |
#6 |
First of all, read the datasheet. A good start for a design are the schematics in the LM4780's datasheet figure 5 and 7.
The non-isolated version has advantages, when it comes to heatsinking, but requires electrical isolation from all touchable metal parts and the ground by means of a mica washer or something similar. The isolated version does not need an additional isolation, but a much bigger heatsink instead. Depending on the quality of your source's output stage a passive pre-amplifier could do, i. e. a potentiometer in a box with RCA connectors and optional source selector. A simple, active preamp could look like this or this.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#7 | |
#8 |
Active speaker design is out the window. The speakers cabinets are not what I had thought. I guess that expands my options though.
Judging by that LM3875 kit, it seems the price is in line with all those T amp kits (Charlize 2, Autocostruire, 41Hz, etc.). I was attracted to the gainclone idea because I heard that gainclones had a very emotional sound. And the T amp tend to be cold and ultra precise. So that's my reasoning for dipping my toe in the gainclone water, not to mention it seems like a doable build for a complete novice. I have decided not to use a preamp. I will include volume control in the build. Any other kit suggestions? Thanks Last edited by irishpatrick33; 16th September 2009 at 06:52 AM. |
#9 | |
I know many people here will say hey there is no way a Gainclone can compete with a commercial amp or the usual How an IC that costs $7 will get you sound quality! Well the best instrument to check sound quality that people have is their ears.you can have the most expensive amp , but if it does not sound good to your ears...it is useless!!also the speakers are a big thing too.make sure you get the right impedance for your amp.Right now My LM3875 integrated amp is in my living room playing beautifully.Some of the above will play louder but the sound is not as good as the Gainclone.Get attention to the power supply. some people like a hefty power supply (a lot capacitance).in my case I use 10000uf per rail.I try with many values like.4.7uf, 10uf, 1000uf, 3000uf, 10000uf, 20000uf.and at the end I decided to leave it with 10000uf per rail.it is all in taste buddy!. Good luck and Be careful with your project!
#10 |
get your first amp running and working to your satisfaction.
Listen to it driving a single speaker. Decide if it meets your aspirations. Only after all that, decide on whether a pair of these + crossover + EQ + PSU can be packaged inside or on the back of the speaker cabinet.
regards Andrew T. |
| kit newbie looking for advice | steamPunk | Chip Amps | 2 | 5th September 2007 07:48 AM |
| Advice (Newbie) | -=PLuKE=- | Multi-Way | 1 | 11th August 2006 04:03 PM |
| Newbie looking for advice | spybld | Multi-Way | 4 | 24th March 2006 10:25 AM |
| Newbie needs advice-help | B.Keary | Chip Amps | 3 | 17th January 2004 08:25 PM |
| Advice for newbie | Clark2000 | Tubes / Valves | 10 | 5th June 2003 10:12 AM |
| Page generated in 0.12780 seconds (85.24% PHP - 14.76% MySQL) with 10 queries |
