| Chip Amps Amplifiers based on integrated circuits |
I am planning to use some my LME498xx driver boards to build a headphone amp. Output devices will be MJE15030/31 since I have some of them.
Before I start doing the output stage. Let me try to use 49810 to direct drive my AKG K240. And see how does the chip perform at low rails < +/-20 V. |
#2 |
Why not try using LM4562 and output buffer like BUF634 or better HA-5002?
#4 |
I had used LME49810 to drive a pair of power Bipolar transistors and it worked as a power amp. It uses the same configuration as the amp from Roender. Sounds good too, better highs that the normal common emitter power amp.
It(design) can easily be extended to drive 3 pairs of power transistors in parallel. I have not completed the project yet even though I have all the parts. |
#5 |
What's the expected output voltage of the 49810 and what's your fidelity target? I've been looking into some low power, low impedance applications lately and chose to go 497x0+49600 as that option specs out better than the 49810 in the mV range. (Still designing the power supply and protection circuits so it'll be several months before I have stuffed boards, though.
#6 |
I simply wired up a simple EF output stage (10 Ohm emitter resistor) using MJE15030/31. Output BJTs are biased at 2.8 mA with a 500 Ohm pot connected between BiasP&M. This bias level is not sufficient for class A operation for practical headphone loads. Higher bias level will be evaluated later.
Here are some test data. Rails: +/- 20 V from a test bench supply Output noise level: 9.5 uV (22 Hz - 22 kHz) Output DC level: 0.5 mV |
#8 |
I changed the pot trim to 5 K by which bias level can be increased. At 100 mA idle current, the performance is super! Output noise slightly increases to 12 uV (22 Hz - 22 kHz). With 400 Hz high-pass filter inserted to filter hums, it reduces to 8.2 uV.
I run the tests for rails +/- 15 V. No noticeable problem observed. |
#9 |
THD+N residual for various biasing points. THD+N is very low when bias current is 3 mA. It does not decrease but increase by increasing the bias. Is gm-doubling (D. Self) causing higher distortion in 10/50 mA?
#10 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me Last edited by peranders; 11th September 2009 at 01:50 PM. |
| LME498xx in branded amplifiers | panson_hk | Chip Amps | 19 | 8th October 2010 09:04 PM |
| Downscaling Zen v.9 for use as headamp | kenev | Pass Labs | 34 | 12th April 2010 01:06 PM |
| LME498xx Driver and Power Boards Group Buy | panson_hk | Group Buys | 3 | 20th July 2009 02:36 AM |
| MC headamp with opa | PTSOUNDLAB | Analog Line Level | 1 | 11th January 2008 09:56 PM |
| It's my AD815 headamp | Kochkurov Maxim | Chip Amps | 16 | 11th May 2006 11:44 AM |
| Page generated in 0.08974 seconds (87.41% PHP - 12.59% MySQL) with 11 queries |
