LME498xx Based Headamp
Old 11th September 2009, 04:51 PM   #11
jcx is offline jcx  United States
if these are the 600 Ohm monitors with 90 dB/V sensitivity then I certainly wouldn't settle for +/-15 drive - bridging gets closer but a discrete output with +/-45 Vsupply would be needed to drive them to 120 dB SPL without clipping
of course the transistor choice is still an order of magnitude too big with only 70mA required by the headphones
AKG K240 55 Ohm "Studio" version would seem to be quite simply served by something like the TPA6120
Old 11th September 2009, 08:20 PM   #12
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
K240 produces 104 dB at 1 V =>10 V rms = 124 dB, QUITE LOUD
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 41 pcb's in interest.
Old 11th September 2009, 10:38 PM   #13
tomchr is offline tomchr  Canada
tomchr's Avatar
I have gotten really good results with the LME49600 and a LME49710 used as a DC servo. The circuit is outlined in the applications section of the LME49600 data sheet.
Eventually I'll get around to actually measuring the darn thing and post schematics and such.
~Tom
Old 14th September 2009, 12:18 AM   #14
panson_hk is offline panson_hk  Hong Kong
panson_hk's Avatar
Originally Posted by peranders View Post
An idea would be to design a really small amp.
Do you mean a headamp or 498xx power amp? I am planning to do the later: a low power (<50W) 498xx + ThermalTrak amp on compact single board.
Old 14th September 2009, 04:37 AM   #15
peranders's Avatar
I meant a physically small amp.
Old 14th July 2010, 10:27 PM   #16
Adrculda is offline Adrculda  Canada
Send a message via MSN to Adrculda Send a message via Yahoo to Adrculda
HERE is one example, but what takes up room is really the power supply itself, specially if you got a few high capacitance caps in there and a half decent toroid adds to the weight too
Old 15th July 2010, 01:14 PM   #17
bssmusic is offline bssmusic  Germany
Default LME vs. LM 6245
Originally Posted by ttan98 View Post
Why not try using LM4562 and output buffer like BUF634 or better HA-5002?
AFAIK is LME the high voltage version of LM (+-24V vs. +- 15V).
You could couple the LMEs parallel ( 22 Ohms in each output to compensate the differences in gain - I did this in a preamp to drive a 600 Ohms output transformer (Jensen)).
G
Peter
Old 16th July 2010, 02:50 AM   #18
BUF634 in 5 pin configuration is $12 on digikey where as MJE15030/31 $1.72
Imax is 250mA VS 4A for the MJE's
ANd whats makes it even better is i have 4 pairs on hand along with 3 LME49810's :P
Old 5th April 2013, 08:57 PM   #19
Telstar is offline Telstar  Italy
Nice idea and good results. I was googling for this kind of headamp after some reading on the lme drivers IC.
Panson, Could you post the complete schematic with values? About 4x gain and 100mA+ for each output transistor is very close to my needs.
I'm trying many different headphone amps this year
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 5th April 2013, 09:38 PM   #20
twest820 is offline twest820
Wow, old thread. You can find the schematic in the LME49600 datasheet. Just change the feedback resistors to get the desired gain. I'd be surprised if 12dB is actually needed, though, and probably neither is a high current buffer like the LME49600 (my earbuds run plenty loud on MAX4477s).
LME49600's a bit cheaper. LMH6321 is almost identical to the 49600 and half the price. And somehow I'm not sure having headphone amplifier with a 4A output current is a feature.
What tomchr doesn't mention is his DC servo, as I recall, uses a JFET op amp instead of the LME49720 shown. I've commented on this in other threads but the LME49720's input bias and offset make it, like most any other BJT op amp, a horrid choice for a DC servo, especially on with a 1M tank impedance. I have no idea what National's apps engineers were thinking. The TL032 and TL072 are good defaults for servos and the LME49880's worth a look if one wants BOM bragging rights.
LME498xx Based HeadampHide this!Advertise here!
LME498xx in branded amplifiers panson_hk Chip Amps 19 8th October 2010 09:04 PM
Downscaling Zen v.9 for use as headamp kenev Pass Labs 34 12th April 2010 01:06 PM
LME498xx Driver and Power Boards Group Buy panson_hk Group Buys 3 20th July 2009 02:36 AM
MC headamp with opa PTSOUNDLAB Analog Line Level 1 11th January 2008 09:56 PM
It's my AD815 headamp Kochkurov Maxim Chip Amps 16 11th May 2006 11:44 AM
