Require advise on tda2050 this schematic
Old 23rd March 2012, 04:19 AM   #11
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default TDA SERIES
check this one its NORAZMI S design
File Type: pdf Amplifier TDA20x0 - LM7815 Bridge 2.0.pdf (103.3 KB, 136 views)
Old 23rd March 2012, 04:45 AM   #12
shravanth is offline shravanth  India
if i use 18v/2amp powersupply then how many watts spearker can i use?
Old 23rd March 2012, 04:49 AM   #13
kuldeepsingh is offline kuldeepsingh  India
kuldeepsingh's Avatar
Send a message via MSN to kuldeepsingh
crude calculations -> 18*2 = 36VA ~ 36 W, efficiency of amp ~ .6
speaker power = 36*0.6 = 21.6 W
2 speakers means, approx 10.8 W each
My Blog
Old 23rd March 2012, 04:51 AM   #14
i have two 20w 8ohm 6'' spks can i use in parallel
Old 23rd March 2012, 04:56 AM   #15
You can use, but if u want good power output, get a 18-0-18V, 6-7 A transformer. 18-0-18 v after rectification and filtering will give ~ 25-0-25 V, it will give approx 35 W power to each speaker
My Blog
Old 23rd March 2012, 04:58 AM   #16
i am not using dual power supply i am using single
Old 23rd March 2012, 05:01 AM   #17
then use 18-0-18 transformer in 36-0 configuration. (simply use the 18 18 wires, don't use 0 line center tap wire). basically you need a higher voltage and more current to deliver output.
But first try with the existing power supply and speakers, i you are satisfied with sound, its OK.
My Blog
Old 23rd March 2012, 05:11 AM   #18
what about this circuit i am using this power supply is 18v/2amps
Old 23rd March 2012, 05:21 AM   #19
The circuit is OK. But output power depends on power supply capacity.
but for future, try to use dual supply circuit. this circuit is mainly for battery powered amplifier.
My Blog
Old 23rd March 2012, 09:02 AM   #20
ok
Require advise on tda2050 this schematicHide this!Advertise here!
Do I really require this box volume? rhythmdiy Multi-Way 6 4th November 2008 04:25 AM
Do BPA require protection??? Leolabs Chip Amps 1 2nd April 2007 04:05 AM
Tda2050 Mr. Triatic Solid State 8 26th April 2004 06:00 PM
Would this require degaussing? ewan Everything Else 4 5th December 2003 10:59 AM
