| Chip Amps Amplifiers based on integrated circuits |
I'm building my second chipamp, using an LM4950. In the datasheet for the mono BTL configuration, the circuit specifies 20k ohm resistors. I don't have any of these lying around, can I use 10k, 21k, or 22k resistors? How will this affect the sound?
#2 |
I built a couple small stereo amps using that chip.I experimented a bit,and decided to use higher value resistors so that the input impedance would be higher.
IIRC,I used 47K resistors,and one 470K resistor between pins 1-3 to get the gain to 10x. the other half of the amp is just unity gain,following the output of the first half. It seemed to me that increasing the value of the resistors improved the sound,perhaps because my source wasn't straining to drive the lower impedance. One note,don't make the bypass cap on pin 8 too large,IIRC 22-33uf was about as large as I could go without having it start to act 'funny'. (I think the datasheet suggests 10uf?) Another note,IIRC i had better results when using lower values for the standby divider,running it "hotter" (more current through the divider chain) seemed to turn on/off the amp more smoothly,without any thumps and pops. Give it a shot with a couple of 1K resistors. -Just remembered,I built a parallel amp with some of these chips. 0.47ohms on each output,paralleled to a 4ohm driver (IIRC the chips are rated for 8ohms). It worked well,not much power though.
Last edited by DigitalJunkie; 30th August 2009 at 02:18 AM. Reason: fuzzy details coming back to me. |
#3 |
Thanks for your advice, but it's a little hard to follow which resistors you mentioned go where..... Would you mind listing which resistors you used where? On the datasheet they are:
RinA: Resistor between Audio Input and pin 1 RFA: Resistor between Pins 1 and 3 RinB: Resistor between Pins 3 and 9 RFB: Resistor between Pins 7 and 9 I would experiment myself to see which work, but I don't have access to any measuring equipment other than a muiltimeter... |
#4 |
Two 10K resistors in series will make 20K , I do this all the time when I don"t have exact Values so i series or paralell values to get the desired Value ...
| Lm4950 | kkchunghk | Chip Amps | 3 | 23rd April 2008 07:42 AM |
| 6N1/6N3 substitution | woodturner-fran | Tubes / Valves | 7 | 31st January 2007 01:15 PM |
| Oscillation in LM4950 Design | rswilson | Chip Amps | 0 | 16th August 2004 12:53 AM |
| screen-plate resistor and grid leak resistor | metebalci | Tubes / Valves | 4 | 26th February 2004 03:18 AM |
| 11k resistor substitution...? | mcelaj | Solid State | 3 | 6th January 2004 04:31 PM |
| Page generated in 0.07462 seconds (77.50% PHP - 22.50% MySQL) with 10 queries |
