high voltage lm3876
high voltage lm3876
Old 11th May 2003, 03:26 AM   #1
zx3chris is offline zx3chris
Send a message via AIM to zx3chris
Default high voltage lm3876
i want to try my hand at making a chip amp and i have a lm3876 and also a surplus tranny i ripped out of an old amp--the tranny is center tapped and 33vac on each side.. after rectify and smoothing this will be around 40v--is this too much for this chip?? data sheet shows 84v max but just wondering if anyone has used this high of a voltage
-chris
Old 11th May 2003, 06:42 AM   #2
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
high voltage lm3876
Well, I can't speak from experience, but I think you won't have problems if you (1) oversize the heatsink from what the datasheet says, and (2) only run well-behaved 8R speakers.
For the heat sink, I would avoid isolating them, and instead come up with a chassis design that would allow them to sit at V- for better heat xfer, making them internal and isolated from the chassis.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 11th May 2003, 06:55 AM   #3
joensd is offline joensd  Germany
Personally I wouldn´t exceed the maximum ratings.
If I understand you correctly you´ve got 66VAC centertapped so
you´d get around +-46VDC which is well above the +-42V maximum rating National Semiconductor recommends.
You can of course give it a try but be prepared it won´t sound good (or even blow???).
You might wanna have a look here for probable consequences of too high a voltage transformer : http://www.diyaudio.com/forums/showt...threadid=13593
Jens
Old 11th May 2003, 10:59 AM   #4
UrSv is offline UrSv  Sweden
UrSv's Avatar
Default Re: high voltage lm3876
-chris
Much to high voltage. If you absolutely need to use that transformer I would recommend regulating the voltage to something more useful which is anything some distance away from 42 V.
And yes somebody has already used that high voltage and he publicly apologize for it.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 11th May 2003, 12:52 PM   #5
ted is offline ted
I was thinking that a possible solution is to "slave" the +/- rails. That is, you use a set of transistors to drive the lm3876 power rails with a voltage that is proportional to the output audio signal. It's something similar to what older amplifiers did to solve the SOA problem of high rail voltages. I think this was called a totem-pole output stage, but in this case, the whole amplifier is being driven this way, even the input stage.
Maybe somebody could comment on if the input stage of a lm3876 would like a dynamic power supply input?
I am not sure if such a trick would work with a lm3876.
Old 11th May 2003, 01:42 PM   #6
Has anybody read the review of Bob Carver´s Sunfire amplifier?
It keeps the supply voltage 6V above what is needed for the momentary output power to minimise dissipation.
The 20 output transistors are just mounted to the case bottom.
Delivers 600W into 8Ohms with an "endless" current capacity.
Should work below 0.5Ohms.
And just took 25 years of development time.
Jens - doesn´t need 600W but likes the idea
Old 11th May 2003, 04:25 PM   #7
colwaiting is offline colwaiting
colwaiting's Avatar
The 33-33 would be just ducky for the R. Elliot 3a amp. Keep it around.
the 3876 is set for 30-30dc which is around 22.5,22.5vac.
There is not much point in exceeding the ratings as the per-chip dissipation is really on the low side with these beasties! althoug the 3886
sez it is ok for 38-38 dc it will reach its thermal limits easily, and is for 8-ohms only.
Old 11th May 2003, 06:47 PM   #8
the speakers i plan on driving are a set of peerless speakers i made a whle back and unfortunately they are 4ohm.. they do sound excellent, and the reason for 4 ohm is that they were going to go in my car, but i had trouble with the clearance of the woofer and my door/window--so i made them for my house. right now i am powering them off an old car head unit and a computer AT supply--they are only getting ~15 watts but sound nice--however they can go up to 150watts so id like to push them if i could--so i wanted to make an amp based on the 3876 (since i have it already) and drive 4ohm safely. i will keep on the lookout for some 22-22 transformers. thanks for the information
-chris
Old 11th May 2003, 06:51 PM   #9
leadbelly's Avatar
high voltage lm3876
zx3chris,
Another thing you can try is straying from the IGC philosophy, and instead building a half-wave rectifying stage for that xformer with big caps to smooth the DC. That'll give something like +/- 22 VDC, so you'll be struggling with lower power rather than thermal protection
Old 11th May 2003, 08:27 PM   #10
if i make half wave rectifying instead of full wave, how can i estimate the dc out?? would [ (VAC/.7) - .7 ] /2 be good?? in that case it would be +/-23VDC... if this works, in most gainclose i always seen people using simply 1000uf caps, what value caps should i use??
-chris
high voltage lm3876Hide this!Advertise here!
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 10:43 AM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 09:05 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 02:32 PM
max voltage for lm3876 - need clarification dvdwmth Chip Amps 13 9th September 2004 05:16 AM
Copyright ©1999-2017 diyAudio
