Old 26th August 2009, 07:24 AM   #1
suds is offline suds  India
Default Another LM3886 Amp
Here is my design of LM3886 based Amplifiers.
The Schematic references is from shine7.com with Permission from Alex. (Thanks)
I have made, Single IC LM3886 Amp, PA100 Type, and PA150 Type.
Link to Images for LM3886 Chip Amp PCB Layout:
http://www.box.net/shared/h0r1ikh2m4
Suggestions / Advice / Comments Welcome..
~suds~
Old 26th August 2009, 02:25 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
The power traces are a bit thin. Make them as wide as you can but at least 3 mm. Three LM3886 can handle 33 A! Since you have got inspiration from shine7, check out how he has made power planes in all high current areas.
/Per-Anders (my first name) or P-A as my friends call me
Old 27th August 2009, 10:42 AM   #3
Thanks for Comment, I have made the changes , uploaded the files..
Will use, 1.6mm Board, PTH Double Side, 70micron copper
~suds~
Old 8th September 2009, 08:15 AM   #4
Default LM3886 PCB's are ready
LM3886 PCB's are ready.. see the above link (images updated)
Will build Amps on weekend, will post images of ready amps later next week.
Link once again : LM3886 PCB Images
~suds~
Old 8th October 2009, 07:03 AM   #5
Here is PSU Proto Image..
http://www.box.net/shared/qcijdyrn2v
~suds~
Lm3886 MJS Chip Amps 3 6th December 2006 11:09 PM
Lm3886 Bpa Tombson Chip Amps 99 21st August 2006 12:04 PM
my new lm3886 amp!!!!!!! sr2002 Chip Amps 24 23rd August 2005 04:28 AM
Lm3886 Pcb soundNERD Chip Amps 122 10th August 2005 03:24 AM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
Page generated in 0.06755 seconds (76.08% PHP - 23.92% MySQL) with 10 queries
