| Chip Amps Amplifiers based on integrated circuits |
I'm stumped.
Everything up to the transformers secondary rails work perfect but once I attach the power supplies I get no voltage. My secondaries read around 25V ac to 27V ac. I attach the snubberized power supplies from chipamp.com and read no DC voltage on the P+ and V+. The LED doesn't light either. Do I have just bad diodes? Can't seem to get past this problem. Thanks for anyones help... JohnnyP. |
#2 |
There's something to be gained by going a step at a time. Connect just the diodes to the transformer, and measure again. If OK, connect the next stage (might be an RC filter) and measure again.
#3 |
Supplies? Are there more than one connected to the same transformer?
I remember going crazy (and driving PD crazy) trying to troubleshoot the exact same problem. It turned out that you can't actually connect the AC1 and AC2 of two different PSU boards to the same secondary, it shorts out. It needs to be AC1 and AC1 together, and AC2 and AC2. I don't know if that's your problem though. |
#4 |
Can you post quality, close up photos of the power supply board, top and bottom? They don't have to be large, but you have to be able to tell what you're looking at.
Also, are you using a light bulb tester? If you are, whether the bulb is lit will tell us whether you have a short or an open. |
#5 |
I'm doing a dual mono configuration from chipamp.com. It looks exactly like the photo there. I'm only attaching one power supply for one transformer. I'm not doing the light bulb test. As far as I measured everything is perfect up to PS boards. How can you test if diodes are bad... Thanks JohnnyP.
#6 |
First, we don't need photos of what the board looks like, we need photos of what you've done during assembly of the board.
Second, the light bulb tester will protect you and the equipment in the case of a mistake, and give a signal indicating when you have something wrong that would otherwise end up in a lot of smoke or worse. It's not for the transformer, they rarely have problems. It's for the power supply boards and amp boards after that. |
#7 | |
#8 |
Hi. Here is some pics. Ignore the chip boards because they're not set up yet. Didn't get that far
#9 |
Between which points did you measure the 25, 27AC voltages?
#10 |
It seems you need a green and blue to AC1 and a green and blue to AC2.
So thats a green and blue with a reading of 25Vac between them.. |
| ChipAmp.com LM3886 assembled kit with acc. | Fast1one | Swap Meet | 3 | 2nd April 2009 08:22 PM |
| ChipAMP LM3886 kit | space-cake | Swap Meet | 1 | 22nd October 2008 08:43 PM |
| LM3886 PCB's or Where is ChipAmp? | DJ4MC | Chip Amps | 6 | 3rd May 2008 02:34 AM |
| Chipamp lm3886 qns | marcusdeming | Chip Amps | 31 | 15th February 2008 04:11 PM |
| Page generated in 0.10971 seconds (82.25% PHP - 17.75% MySQL) with 11 queries |
