| Chip Amps Amplifiers based on integrated circuits |
I bought a TA2020 based amp on the Bay (cheap!) to try out Class T (I'm a Class T-uber normally) that requires a 14-15vdc supply at around 5 amp capacity. I have a wall wart-style PS (from a laptop) that puts out 16.9vdc with a 5+amp capacity and I wonder what you all think about using it for the 2020. If it's a reasonable idea, what's the best way to drop the voltage about 2V?
If not, I might be able to come up with a PS design using a voltage regulator, but if anyone has a recommended PS for me to look at, I'd be grateful. Thanks. Carlp |
#2 |
The simplest method would be to put a few diodes in series on the power lead to the amp. Each one will drop approx 0.7V,so 3-4 diodes would be needed.They will get a bit warm,but not much. I can't think of any 6A diode PN's off the top of my head though.
#3 |
Interesting idea. Thanks. I happen to have some MR751 Fast Recovery diodes. These are rated 100V, 6A and have a forward voltage drop (max) of .9v. Should work? Please let me know if this isn't a good idea.
Carl |
#4 |
I also bought cheap TA2020 (Lepai ) froom ebay as a tryout with this kind of amp, and it was without power supply. I connected it to a supply from creative speakers which seamed like a good choice since it's rated to 12V and 4.2A and is quite heavy. I even didn't have to change the connector. But to no avail, the amp burnt when plugged, so I need advice on what went wrong. I had one speaker connected, and have no confirmation that the power supply is in working order (bought it on the market). I would like to try with another amp, but want to avoid this happening again. The amp produced crackling and distorted sound on 12V/1.25A power supply before.
#5 | |
It's not "12V and 4.2A", it's "12V @ 4.2A". This means that with current draw of 4.2A the voltage will be ~12V. Unloaded the voltage is probably >16V.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#6 | |
#7 |
Bingo.
I was just googling "12V 4.2A" creative power supply, and it looks like they are indeed AC output.
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| Need recommendation for power supply for TA2020 | maurycy | Chip Amps | 0 | 25th November 2008 03:05 PM |
| Parallel a dual power supply or two power supplies? | Thunau | Power Supplies | 12 | 16th February 2007 04:21 AM |
| selling high current power supply for power amps. | ericpeters | Swap Meet | 0 | 14th January 2005 02:21 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
| Page generated in 0.09096 seconds (77.62% PHP - 22.38% MySQL) with 10 queries |
