Old 23rd August 2009, 11:33 AM   #1
EBM_dude's Avatar
Default TDA2030 swith on thump
At the moment, I'm modding an "Audiophile AA-941" amp that is equipped with two TDA2030A. I plan on swapping the 2030s with TDA2050s. What bothers me is that extremely loud switch on noise. I'm afraid it will kill speakers on the long run. Is there any way to get rid of it or just make it less loud?
Old 23rd August 2009, 11:44 AM   #2
jaycee is offline jaycee  United Kingdom
Best solution - add a DC protect circuit with a power-on delay
Old 23rd August 2009, 11:54 AM   #3
EBM_dude's Avatar
This is what I was thinking, too. But I didn't want to do it because I think that the TDA20x0 is "not worth it" and I'm shooting for a LM3886 in the future.
Old 23rd August 2009, 02:30 PM   #4
sangram is offline sangram  India
Two SPDT relays, one BD139 and one capacitor, plus two resistors. All you need for a delay circuit (not DC protect, just the delay). I used two 12V relays hooked up in series to the +28V power line of a LM4766 + Alien DAC combined amp. The power amp was silent, but the Alien had some flatulence on switch-on. I tried to use the muting circuit on the 4766 to create a delay but it didn't work at all, and I had all the bits in my junk box so it took me all of 10 minutes to work into the circuit. Plus, it was on a separate board so using it somewhere else is a simple matter.
Old 23rd August 2009, 03:09 PM   #5
EBM_dude's Avatar
I should have a few relays in my parts bin.Do you think I can substitute the BD139 with a Darlington transistor? I have some 2SD1415. That's a nice NPN Darlington used in car's ECUs to switch on injectors.
Old 23rd August 2009, 05:00 PM   #6
Just wondering how it's wired up ? Is it a single supply amp? The problem in that case is the output capacitor charging, which isn't easy to solve.
Old 23rd August 2009, 05:13 PM   #7
EBM_dude's Avatar
It's a split power supply using a 0-12VAC trafo. It doesn't have or need output caps. DC offsett is around 1.2 ... 1.5 mV.
From studying the TDA2050 datasheet, I think the caps for the inverted feedback DC decoupling are the culprit here. So that switch on thump is a design "feature". I wonder what will happen if I just short that cap....
Old 23rd August 2009, 06:06 PM   #8
As long as the transistor has Ic ~200mA it should work fine.
How is the amp generating a split supply from a single transformer winding? The charging current at the midpoint is causing the thump. Look at the application notes for Single-supply applications from some of Nat Semi's power amp datasheets (LM3886 has it IIRC). It is not a very easy problem to solve.
The Ci which you have identified keeps the amp's DC gain at unity. Shorting the capacitor may create a slightly higher offset voltage than is normal. It's not safe to do this and tests with your actual speakers.
Old 23rd August 2009, 07:39 PM   #9
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
When I had my TDA2030 based amplifier, which also ran from split supply, I don't actually remember there being any turn on thump. I used a 15v, 0 15v dual secondary transformer (only to be used with 2030AV models and even then I had to drop a bit in reality!).
Old 23rd August 2009, 10:27 PM   #10
EBM_dude's Avatar
The darlington transistor can switch up to 7 Amps. Those (saturated) injectors it usually switches draw a bit more than 1 Amp. That's why some folks get fried ECUs if they swap their satured injectors (12-16 Ohms) with peak and hold ones (1-3 Ohms)...
The trafo and rectifier part of the amp looks like this:
BPA possible with TDA2030? mateo88 Chip Amps 11 19th February 2012 05:44 PM
FS: Mean Well Swith Mode Power Supply nic6paul Swap Meet 2 2nd July 2009 10:37 PM
Potentiometer with on/off swith & balance dytln_02 Parts 0 16th July 2006 07:15 PM
Page generated in 0.09968 seconds (78.38% PHP - 21.62% MySQL) with 10 queries
