Safety timer/relay in JLTi/VBIGC not working as hoped
Old 20th August 2009, 10:39 AM   #1
gaplessophile is offline gaplessophile  New Zealand
Default Safety timer/relay in JLTi/VBIGC not working as hoped
I've got a bit of a problem I'm hoping someone might be able to help me out with.
I recently built a JLTi, or tube-buffered GainClone, according to this design here
I then added a relay with a timer circuit, as per Nuuk's instructions, to short the output of the valve while it's warming up so that I don't damage my speakers.
As instructed by a thread I read here somewhere, I wired my relay to short from right after the coupling capacitor (the 3u3 in the diagram above) to the signal ground (I wired everything up according to this diagram here).
Unfortunately though, rather than completely shorting out the DC offset, while the valve's output is shorted as above, both channels of my amp output around -200mV DC, which I figure isn't too good. When running normally, the amp's DC offset is around -60 to -80mV.
Worse still, when I switch the power to my amplifier off, even with the valve's output correctly shorted by the relay, which switches as soon as it loses power, the amp's DC output reaches about 3V as it cools down (could it be that the chips' power capacitors are draining unevenly?).
Can anyone spot what I'm doing wrong? Am I shorting to the wrong place (currently just after the 3u3 capacitor in the diagram above)?
Also, I noticed after I'd built my amp according to the JLTi design above, that the VBIGC design on Nuuk's website looks significantly different:
Did I pick the wrong design? What are the relative merits of these two designs?
Thanks heaps!
Old 20th August 2009, 10:48 AM   #2
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
1 M ohmn as feedback is unsuitable. Joes values are better and also to use the voltage divider for the feedback.
Where do you short the tube?
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 53 pcb's in interest so far.
Old 20th August 2009, 11:06 AM   #3
Cool, I guess I picked the right design then.
I shorted just after (to the right of) the 3u3 coupling capacitor - shorted to the signal ground.
Old 20th August 2009, 12:13 PM   #4
Ted205 is offline Ted205  United Kingdom
Ted205's Avatar
why not short the output of the amp ?
i.e after the lm3886
or better yet use the mute pin on the chip
Old 20th August 2009, 12:17 PM   #5
It's an LM3875, so no mute pin unfortunately. Is it ok to short the output? Will that not damage anything?
(EDIT: Sorry, for confusion, it is a 3875, not a 1875 as I previously said here. Either way, no mute pin.)
Old 23rd August 2009, 05:10 AM   #6
I'm afraid I'm still completely stumped by this.
How are other people going about protecting their speakers in a tube-buffered gainclone?
Is my issue with the 3V DC offset during power-down (even with the tube effectively out of the circuit) unusual?
Thanks heaps for all your help!
Safety timer/relay in JLTi/VBIGC not working as hopedHide this!Advertise here!
Need Advice with Timer Relay Shut Off Bryan Tubes / Valves 7 25th October 2005 08:43 PM
Timer Relay Bryan Tubes / Valves 6 15th September 2005 12:45 PM
Quick Relay/Timer Help Needed woodrufj Parts 3 24th June 2004 07:05 PM
what does the 1n3 cap in JLTi VBIGC do? sandro600 Chip Amps 2 5th March 2004 08:40 AM
A Vbigc Ropie Chip Amps 19 11th February 2004 06:56 PM
Copyright ©1999-2017 diyAudio
