Bridge & Parallel 4 x LM4780 - Basic wiring diagram needed
Old 12th August 2009, 10:23 AM   #11
if you plan to bridge an 8ohm speaker using chipamps then I suggest three channels in parallel rather then just two.
I am recommending that you build a BPA300 into 8ohm if you feel that you must use chipamps for your 200W into 8ohm loading.
regards Andrew T.
Old 12th August 2009, 02:11 PM   #12
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Bridge & Parallel 4 x LM4780 - Basic wiring diagram needed Send a message via AIM to Peter Daniel
Default Re: Bridge/Parallel configuration
Originally posted by GAH
Thanks Redshift187 and Peter! Now I understand. With such a configuration is there any sonic benefits besides the extra power when using 6 to 8 ohm speakers (Harbeth SHL5)?
I always avoid paralleling chips, they sound slightly inferior this way comparing to a single chip. I don't even want to think what 3 of them will sound like in parallel.
Besides, we are talking here about LM4780, since it is a dual chip, it is very inconvenient to use 3 halves in parallel.
A single LM4780 paralleled and then two of them bridged, will have no problem with 8 ohm loads.
There is a certain advantage to running chips in bridge: I find the dynamics improve and there is more body to the music, you can read more about it here: http://6moons.com/audioreviews/47labs5/gaincard_3.html
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 12th August 2009, 02:26 PM   #13
Yes Peter,
he could try running the dual chipamp in bridge mode and then parallel 3 of them to give the transient peak current ability into an 8ohm speaker.
But rather than build up 6channels of chipamp, go to a discrete output stage with discrete drivers using lme498xx series voltage amp driver stage or go fully discrete.
regards Andrew T.
Old 12th August 2009, 02:37 PM   #14
Originally posted by AndrewT
Yes Peter,
What I meant was to parallel each dual chip first and then run them in bridge, not paralleling brided amps which is completely impractical and unpredictable.
While going fully discrete may have certain advantages, using chip amps is quite tempting too and both approaches can produce very satisfying results.
www.audiosector.com
Bridge & Parallel 4 x LM4780 - Basic wiring diagram neededHide this!Advertise here!
LM4780 Parallel/Bridge - Prelim Schematic otherside Chip Amps 41 5th January 2007 03:23 PM
Basic 5066 Diagram for the Novice! audio1st Class D 14 14th September 2006 05:20 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 05:37 AM
can i use this wiring diagram mitchell Car Audio 3 23rd August 2004 09:50 PM
Wiring diagram for S&B Tx102 TVC needed Peter Daniel Parts 5 10th October 2003 10:56 PM
