| Chip Amps Amplifiers based on integrated circuits |
I'm new to building amps so I hope some one can help. I'm building a LM3886 kit from chipamp.com and am getting 2mvdc from the psu. I thought it should be about 30vdc. I've rechecked the entire pcb and can't find the problem. Are there any suggestions. chipamp does not respond to my emails.
Thanks Mike |
#2 |
pull out the mains plug immediately.
You may have left a wire unconnected, can it short while you are fiddling around? or You may have wired the mains transformer wrongly. This could destroy the transformer if you try connecting it to the mains supply again.
regards Andrew T. |
#3 |
Are you using a light bulb tester? If not, you should make one and use it before continuing.
#4 |
a light bulb tester, and a drawing for us to look at would be great.
#5 |
Thanks for the replies,
The transormer is wired correctly and there is the proper acv. when testing from v+ to v- there is the same acv. Is this the way it should be? I thought it should be dcv. I'll build a light bulb tester this weekend. I've been going over this psu for a week, even disassemled it and resolderd everything. Attached is a picture of the psu from chipamp.com. Mine looks the same. Thanks Mike |
#7 |
does the kit have two or one bridge rectifiers?
if one, than the secondaries hook up to that at ~ and ~ pins on the rect. the dcv is output at + and - pins of the rect. your center tap than goes to ground. if two, than your transformer must have dual secondaries, thus each one (pair of wires) would connect to one of the rectifiers. !!!!! if your + and - pins have acv on them, this means so do the capacitors, and they soon could explode on you. if you could draw an mspaint diagram up real quick, showing how you connected transformer wires to the pcb. edit i see it has diodes. still, we cannot tell what is going on until we can see how it is connected. |
#8 |
Thanks again,
there are two rectifiers. the pcb is clearly marked for the ac inputs, binding posts are soldered there as per instructions. the transformer has two pairs of secondaries. I have never used ms paint so attached is a jpeg of the boards. it is pretty straitforward as to where everything goes and polarity. The bands on the pcb for the diodes indicate metal side. |
#9 |
Since you have already answered the question about diode polarity, what about the large capacitors?
#10 |
Hi Mike,
Can you please clarify - you say the PSU output is 2mV DC in the first post, but then that it's the same AC out across + & - as the AC input, in post #5. What is the actual output? It'd be highly unusual for AC to get past the rectifiers if they are correctly aligned and properly functional, and as you state, it's almost foolproof on these boards because of the band markings, if the diodes are those supplied by Chipamp (MUR860?). If not, make sure the pin polarity is correct (I'm not sure if all diodes in this package are pin compatible - maybe they are?). BTW I've built one of these kits and it's a nice, compact, good sounding unit when up and operating. Stuey |
| 12 volts to 6 | Dan2 | Car Audio | 36 | 23rd November 2007 07:35 AM |
| power transformers 220 volts to 110 volts | garydmd | Chip Amps | 3 | 7th April 2007 03:52 PM |
| TOO many volts ????!!!! | cbutterworth | Tubes / Valves | 6 | 16th December 2006 11:50 PM |
| Gainclone is on 120 volts will it be fine at 220 volts? | Jimmy154 | Chip Amps | 7 | 29th June 2005 01:10 AM |
| Where do all those volts go? | Stocker | Solid State | 2 | 9th April 2004 08:06 PM |
| Page generated in 0.10138 seconds (77.87% PHP - 22.13% MySQL) with 11 queries |
