| Chip Amps Amplifiers based on integrated circuits |
#11 |
something is either wired wrongly or some component/s is/are inserted incorrectly and/or damaged.
Build that bulb tester, even the simple one without any switches and power your project from the bulb tester.
regards Andrew T. |
#12 |
Hello again,
Sorry I missed yesterday's posts. I had to get some work done out in the woods. We had some cool weather and had to work on fire protection. Anyway back to the thread. Pulled of the caps, there is both very low dcv and about 26vac. I just checked the diodes again, and am getting low voltage both ways. .945v pos. lead to anode, and .415 neg. lead to anode. This is probably the problem. I will make a light bulb tester before I move on. Thanks Mike |
#13 | |
Ask for help and ignore the advice you are given. Is this the way to get further help?
regards Andrew T. |
#14 |
Howdy Mike,
I can't quite make out where you're measuring, but if that's what's on the rails before the caps but after the diodes, it sounds like the diodes are knackered. Is there a possibility you overheated them when soldering? From memory, though, these boards don't suck out much heat so you shouldn't have needed to use too much to get solder flowing. This is mainly a problem when you're soldering to a board with a fairly big copper trace, or a plane of copper. This pulls the heat out of a smaller tip. Photos of your work showing the transformer wiring and both sides of the PSU board would may help. You'd be surprised what people on here can spot! Stuey |
| 12 volts to 6 | Dan2 | Car Audio | 36 | 23rd November 2007 06:35 AM |
| power transformers 220 volts to 110 volts | garydmd | Chip Amps | 3 | 7th April 2007 02:52 PM |
| TOO many volts ????!!!! | cbutterworth | Tubes / Valves | 6 | 16th December 2006 10:50 PM |
| Gainclone is on 120 volts will it be fine at 220 volts? | Jimmy154 | Chip Amps | 7 | 29th June 2005 12:10 AM |
| Where do all those volts go? | Stocker | Solid State | 2 | 9th April 2004 07:06 PM |
| Page generated in 0.06599 seconds (77.58% PHP - 22.42% MySQL) with 11 queries |
