| Chip Amps Amplifiers based on integrated circuits |
Hi
I was using only one of my 2.1 DIY amp to push my subwoofer, since the Onkyo receiver was doing all the work, bu the I found out that I can use 2 LM3886 in parallel to push my subwoofer, duplicating the power. Theorically now, I am using 100w instead of the 50w, but what is the benefit of this? I didn't notice any difference in the sound at all. The only difference is that now they are a little bit warmer than before ( maybe becouse of the 2 amps working, duh!). I was expecting that the sub was going to be a little more louder, but it is just the same volume. |
#2 |
Doubling the power should ideally only give you a 3dB difference in maximum output level. Depending on the speaker etc. you'll probably get a little less than 3dB which, due to the logarithmic nature of human hearing, is only a barely perceptible difference. Again, we're talking about _maximum output level, which you may or may not ever reach during regular listening - possibly only during loud bass drum hits or explosions in movies.
-j |
#3 |
And making they work in a bridge circuit is the same thing?
#4 |
This article here explains it better than I can:
http://en.wikipedia.org/wiki/Bridged...led_amplifiers -j |
#5 |
if you have a chipamp delivering a maximum output of 60W into 8ohms, then it is effectively driving the speaker with a 21.9Vac signal (~31Vpk). Putting two of these chipamps in parallel gives the same drive voltage to the speaker, i.e. 31Vpk. The amps try to deliver equal current to the speaker load, so each amp effectively deliver half the current that a single chipamp would do. The parallel chipamps driving a 16ohm load (what each of the parallels sees as a load) will probably achieve a maximum output of ~32Vpk (+0.3dB). If you can hear that increase of 0.3dB you will be doing very well. Don't even think about bridging the chipamps. Each chipamp in the bridged pair will see an effective load of half the speaker impedance. A 60W into 8ohm amplifier will see a 4ohm load and try to send that maximum signal of 31Vpk into the 4ohm load. It will shut down repeatedly due to over current and over temperature. It might just about manage 28Vpk on a transient. That is equivalent to ~56Vpk into your 8ohm speaker. About 200W into 8ohm. You are going rapidly into melt down. You will need to redesign the amplifier to allow it to be bridged. Just to put you off a bit more all these chipamps are crippled by the very limited peak current they can deliver and this gets worse as the chips heat up.
regards Andrew T. |
#6 |
i guess u may have more hearable difference if you have 4 ohm subwoofer rather than a 8 ohm woofer. just check your subwoofer impedence
. . .. ... ..... ........ ............. ..................... .................................. My Best LM3886 PCB layout
#7 |
i think there is confusion on the difference between paralleling the amps and bridging the amps. There will be no change in gain with parallel.
My DIY audio projects- PartTimeProjects.com. |
#8 | |
The reasons for paralleling is the presumed ability to drive a 4 ohm speaker with same rail voltages of an 8 ohm, IF the gains are perfectly matched. If not then the mismatched voltages produced will create circulating currents in the amp chips causing heat and inefficiencies. Tiny voltage mismatches can produce huge currents across the small output ballast resistors (typ 0.1 ohm). Probably best to tweak the final gains to within 0.1% or less. The initial tolerance build up using 4x 1% resistors is not good enough. The circulating currents may be the cause of your running hotter. Parallel operation s/b really done by extra precision and not for newbies to achieve the 3dB power gain. circulating currents with 0.1% Ipk =0.1%*30V /(2*0.1)=1.5A still high
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#9 |
Scratch calc above is 1% not 0.1
See AN -11192 fig6 http://www.national.com/an/AN/AN-1192.pdf Using four ultra precision 0.1% resistors for 2 gains. estimate initial tolerance using root sum of squares method ~final gain toler between amp outputs = 0.2 % calculate circulating current using Vo = 34Vpk undistorted Ipk = 0.002*34V/(2*0.1 ohm) = 0.34 Amps peak
#10 | |
And drop your speaker impedance, it will be the same maybe worse (Vgains matched?). If you just add another sub in parallel you can see the most gain in volume and power.
| LM3886 parallel PCB's | jmillerdoc | Chip Amps | 0 | 27th May 2009 08:26 PM |
| parallel lm3886 question | ryan750 | Chip Amps | 2 | 23rd October 2008 09:37 AM |
| LM3886 Parallel Use | Rachel | Chip Amps | 71 | 2nd July 2006 04:24 AM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 10:24 AM |
| Can I parallel transformers for a LM3886? | soundNERD | Chip Amps | 14 | 29th October 2003 01:34 AM |
| Page generated in 0.11249 seconds (81.48% PHP - 18.52% MySQL) with 10 queries |
