| Chip Amps Amplifiers based on integrated circuits |
http://cgi.ebay.com/NEW-LM3886TF-2X6...kparms=65%3A12|66%3A2|39%3A1|72%3A1234|293%3A1|294%3A50
This ad seems very deceiving to me. They say DIY, but the item shown in the photos is pre-made. They also don't say whether or not you need a transformer. It might be a DIY kit that has been assembled already. I don't know. What do you guys think? Will I need a transformer for the PSU of this? |
#2 |
The kit is for a stereo amp (2 power amp boards) and a power supply board.
You will need to supply a transformer. A twin secondary 18vac would do. You will need to know how to wire the transformer to the mains and the power supply board and house the amplifier in a case so that no-one gets electrocuted. Do you have the skills? |
#3 |
I´m amazed!
No way to go without a transformer, typically 24V center tapped secondaries, approximately 200 - 300VA.
#4 |
the PCBs look the same as some I bought from another seller. I had my doubts about whether all the components were genuine or fakes. The assembled PCBs play fairly well into 8ohm speakers using either 15+15Vac or 25+25Vac transformers. I cannot vouch for the pre-assembled versions. Be careful with dissipation of the TF chips. They need bigger heat sinks and are expensive to cool on 4ohm loads. You need chassis heatsink/s hardware transformer The budget for these four items is likely to be two to ten times the $40 of the PSU and 2amps.
regards Andrew T. |
#5 |
I was recommended a:
28V--0--28V Does that mean Parallel-Amperage-Series ?? Can somebody give me a direct link to Newark or Digi-key? |
#6 |
Hi. 28v secondaries will be too high. Your chips will likely fry eventually. 28v will be 28 * 1.41 = 39.48v. +-40v is too much, with mains fluctuation your chips will explode. Those kits are fine. www.customaluminumboxes.com will create a custom encosure for you at an amazing price. just give them dimensions and general details. You should get an 18-0-18 VAC or 18-0 18-0 VAC transformer, rated at at least 200va to supply both of those chips. At (18*1.41=25.38VDC) your chips won't get very hot, affording you a heatsink that won't take up your whole chassis.
#7 | |
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#8 | |
I use twin 30vac trannys with my LM3875 monblocks. No problem. |
#9 |
Sorry about asking for a direct link... lol
#10 | |
I use 230:25Vac 225VA that gives +-37.7Vdc (when the mains is at 240Vac) into the amplifier when drawing quiescent current. On the rare occasions that 254Vac may arrive I expect it to give ~+-40.5Vdc
regards Andrew T. |
| Arc Welder Transformer used to power Amplifier | John Biles | Solid State | 53 | 18th July 2011 04:17 PM |
| transformer amplification amplifier | damianl | Solid State | 19 | 11th October 2010 10:00 PM |
| Need to replace the transformer in this amplifier | Kramerguy | Solid State | 35 | 23rd December 2008 07:54 PM |
| Is this transformer good for power amplifier | ostie01 | Solid State | 10 | 14th August 2006 02:53 PM |
| amplifier without transformer | csl113 | Solid State | 2 | 17th June 2005 02:28 PM |
| Page generated in 0.13074 seconds (85.45% PHP - 14.55% MySQL) with 10 queries |
