Old 31st July 2009, 10:24 AM   #11
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
I have a 30x2v AC 225VA toroid, and it gives 41-42v DC depends on load. However I have never thought to apply it a chipamp! I think its dangerous..
What if the mains increases only up to 240v???
Best regards,
Ozgur
Old 31st July 2009, 10:37 AM   #12
the rated input voltage to rated output voltage ratio is critical if you want to run at close to the National maximum voltage specification.
I reckon a 240:28Vac 300VA transformer (6% regulation) feeding a pair of 3886 chipamps will be just above the +-42Vdc maximum quiescent specification. But when significant power is drawn from either or both amplifiers then the supply will drop below the +-42Vdc spec maximum.
I recommended 240:28Vac a long time ago as the maximum to supply an 8ohm loaded pair of chipamps and got shouted down as far too big a supply voltage.
Measure what you have and monitor temperatures, but if you choose to run above National's specification maxima then the risks and consequences are wholly of your own making.
regards Andrew T.
Old 31st July 2009, 11:12 AM   #13
The trouble with the 2x30 V transformer is that it is recommended in National's AN-1192, but people tend to overlook the fact that it is only recommended in combination with 8 Ohm speakers and with profound heatsinking. As long as an amplifier is not permanently connected to a dedicated driver in an active speaker or similar set-up, you can not be sure that it will never be connected to a 4 Ohm load. Just as little as you can be sure that nobody will ever turn the volume up, while your amplifier is connected to a 4 Ohm load, when it should not be.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 31st July 2009, 01:44 PM   #14
all is why that voltage shouldn't be recommended to a beginner. 18-0-18 will give him the ability to drive different loads, different volumes, with assurance that the chips are not getting very hot as long as he uses a sink that isn't incredibly small.
Old 31st July 2009, 08:22 PM   #15
kizm0 is offline kizm0  United States
Alright..I'm still having a hard time understanding this but..
With some googling I found this:
http://www.newark.com/jsp/search/pro...FC-GB100000001
Old 31st July 2009, 08:43 PM   #16
guitvinny's Avatar
It's not so hard, you have basically 3 things to check :
- Primary winding, is it for 120 or 240 V
- Secondary winding, in your case 18 - 0 - 18
- VA rating, which is *grossly* the power the transformer can handle
The 2nd one from Newark looks very nice, the first one can only deliver 4 VA... its going to fry.
Old 31st July 2009, 08:59 PM   #17
netbug is offline netbug  United States
This is what I'm running in a dual 3886 chipamp
25v+25v 250va
http://www.parts-express.com/pe/show...number=122-625
Safe using 8ohm speakers a decent heatsink
As stated earlier 18v+18v would be safe for 4ohm
http://www.parts-express.com/pe/show...number=122-620
Old 31st July 2009, 09:44 PM   #18
Didn't have to get to other people sending me their parts, but oh well.. Thanks a lot. I now have a better understanding of Transformers.
Arc Welder Transformer used to power Amplifier John Biles Solid State 53 18th July 2011 04:17 PM
transformer amplification amplifier damianl Solid State 19 11th October 2010 10:00 PM
Need to replace the transformer in this amplifier Kramerguy Solid State 35 23rd December 2008 07:54 PM
Is this transformer good for power amplifier ostie01 Solid State 10 14th August 2006 02:53 PM
amplifier without transformer csl113 Solid State 2 17th June 2005 02:28 PM
Page generated in 0.09475 seconds (82.15% PHP - 17.85% MySQL) with 10 queries
