Old 29th July 2009, 07:31 PM   #11
gfiandy is offline gfiandy  United Kingdom
Audio Engineer
gfiandy's Avatar
Another thought. If you drop the requirement to do it in a single stage you could easly make something using two cheap dip parts. Such as a LM386 0.5W amp chip and almost any cheap opamp.
This would be more reprisentative of a real world situation where you would normally use an opamp as a preamp stage and use a seperate power amplifer. If you are goign to do a little PCB the difference in complexity to solder two dips agains one is almost nothing. Could work out cheaper than making a SMT carrier and then a seperate PCB for the circuit.
Andrew
Help with TDA2003 amp Tahmid Solid State 7 14th July 2008 05:21 PM
sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 jarthel Chip Amps 5 19th July 2007 12:37 PM
whats the difference between inverting and no inverting mikee55 Parts 1 7th January 2007 10:36 PM
Aleph Phase Inverting / non inverting macka Pass Labs 9 22nd February 2006 07:01 PM
Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB Alexander Rice Chip Amps 9 27th March 2004 06:53 PM
Page generated in 0.06607 seconds (71.50% PHP - 28.50% MySQL) with 10 queries
