| Chip Amps Amplifiers based on integrated circuits |
#21 |
Wire the fan to only turn on at high load.
If you really want quiet, water cooling is the way to go. Or just switch to a hybrid digital design. (BTW, if you ask for quiet cooling for a high speed CPU, they'll likely agree with water cooling.)
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#22 | |
#23 | |
Go recompute, star. Water cooling can never be more quiet than passive. This is why you don't listen to pure logic when designing anything practical. Computers (such as the quoted poster) have the logic thing down great, but can't come to reasonable suggestions. But this is all an aside from the point. I use a heatsink similar to David's (dfdye) for my stereo pair of LM3886TF's. It works fine with my +/-24 V supply, doesn't even get warm. I would not be able to use my heatsink with 4ohm loads at +/-28V though, due to the TF package. For your application, I would use one slot A heatsink per chip. (with widely spaced fins, dfdyes are a good example). -David |
#24 | ||
Your approach is to assume that ormo will use the amplifiers the same way you do, at civilized listening level and comfortable ambient temperatures below 80 °F, which is around 27 °C. Andrew's approach to show up, how to calculate the heatsink for a given set of conditions is better, because it also works, if ormo uses the amplifier in one of numerous different ways. Quote:
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#25 |
It's actually possible to have water cooling without a water pump. The water will become less dense as it warms up, and that can be taken advantage of to make it flow. (It would take more work in design, but it could work in theory.) Water has a much higher heat capacity than air so it is more practical for natural convection. That will so help keep temperatures more stable.
If you use a liquid with a low boiling point (such as tetrafluoroethane), it works even better since the liquid boils into a vapor, which is much, much less dense. Indeed, such an approach is very common and is known as heatpipes. However, the tools required to make one of those cooling systems cost quite a bit and therefore is generally not cost effective for most DIYers. (I have some HVAC tools I used to repair an A/C at my old house so I do have all the tools required. But most DIYers do not.) Or just go for a hybrid digital design. For high power levels (which was once 100w and above but is now more like 5w and above thanks to the decreasing cost of new technology and rising cost of certain raw materials), it costs less to initially build and less to operate. The extra cost of a hybrid digital design is more than made up for by reduced costs in heatsinking and power supplies. Indeed, a 60w hybrid (2x TPA3122D2) one of my friends built doesn't even have a heatsink for the chips and only two small heatsinks for the power supply (old 90w laptop supply). Even at high output, it barely runs warm.
#26 | |
Is a 10 W @ 10 % THD amplifier (TPA3122D2 acc. to datasheet) an adequate subsitute for a 68 W @ 0,1 % THD amplifier (LM3886 acc. to datasheet)?
#27 | |
Of course, there's also modules that take most of the work out of building a hybrid or pure digital amplifier. They're very easy to use and are therefore highly recommended for beginners. Avoiding EMI can really be as simple as enclosing it in a metal box and using filters on inputs and outputs. At high power levels (above about 5w at this point), standard analog really doesn't make sense as it would cost more due to heatsinking and power supply requirements. And the frequency range is actually improving to the extent that some engineers are actually working on digital DSL line drivers, which is a very demanding application (well into the low MHz).
#28 |
I have built 6 monoblocs using LM3886TF chips with supply of +-25V and transformer rating of 120VA. As most here have experienced, when you use them for normal domestic use, they barely get warm even at relatively loud levels. Ofcourse, it would depend a lot on speaker sensitivity.
However, when I used these to really push 12" PA speakers (2 way, 99db sensitivity) it didn't take long for the heatsinks to really heat up and it did take long for them to cool down. My heatsinks measured 200 x 88 x 33mm. The fins were 25mm and the heatsink base plate was 8 mm thick. All of these amps have been installed in a friends place and I won't be able to re-test. Andrew is right that one would require compliance with National's specs when you have reactive loads and high drive levels.
Sam |
| LM3886 Heatsink size? | henkel | Chip Amps | 28 | 11th April 2011 02:14 AM |
| Aluminum lid for a Radioshack Project Enclosure as a heatsink for an LM3886? | haziz | Chip Amps | 1 | 6th April 2009 03:08 PM |
| Required heatsink for 3 LM3886 in parallel? | CJ900RR | Chip Amps | 7 | 2nd January 2009 05:19 PM |
| LM3886 & Others Chip Amp Heatsink Clamp Solution | MartyM | Chip Amps | 7 | 18th October 2007 04:36 PM |
| Heatsink approval needed for lm3886 | svbear | Chip Amps | 36 | 3rd August 2007 05:09 PM |
| Page generated in 0.11739 seconds (85.00% PHP - 15.00% MySQL) with 10 queries |
