Old 22nd July 2009, 11:39 AM   #1
Default weird 1875 problem
Hi I have built a few 1875 amps but the last two have exhibited a strange problem. On higher volumes i get a distortion/crackling from ONE of the channels - no its not the speaker, i swapped them and the same thing happens in the other one. it usually happens when the music hits a portion with a higher volume (what do you call that - crescendo ?? ) anyway any suggestions welcome.
Old 22nd July 2009, 11:42 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
How about the volume potentiometer?
lineup
Old 22nd July 2009, 11:45 AM   #3
wow that was fast. no no volume pot, using ipod.
Old 22nd July 2009, 12:07 PM   #4
jeff mai's Avatar
Sounds like you're clipping.
Old 22nd July 2009, 12:27 PM   #5
can you intercept the signal line into the power amp and measure the average signal when you "turn up" the volume?
What gain have you set the two power amp channels to?
Are they both the same? Check the resistors.
regards Andrew T.
Old 22nd July 2009, 01:02 PM   #6
Stuey is offline Stuey  Australia
Are you using a pre-amp?
Given that the last two amps have done the same, maybe it's a fault with a channel in the pre-amp? Try a known good power amp if you haven't already.
Alternatively, is there any component you may have used in common in both amps (such as the volume pot mentioned above)?
Cheers
Stu
Old 22nd July 2009, 02:16 PM   #7
Hi was out for a while. Andrew will try measuring. Stuey no pre amp, just an ipod. I had a thought that it might be connected to the 3.5 jack , maybe its not connecting well enough inside the ipod ? does that make any sense ? Otherwise its back to rechecking all the groundings, that is something i have learned with these amps it is 90% of the time a ground fault . I just dont get why it is only at higher volumes this is happening, btw the gain is set at 22 : 1 for one of the amps (both channels of course) and 30:1 for the other.
Old 22nd July 2009, 03:05 PM   #8
Tomorrow i will try a different source and see. Thanks for all the quick input.
Lm 1875 problem? :( fr1s Chip Amps 50 16th February 2009 03:01 PM
weird hum problem audiopro Tubes / Valves 4 31st August 2008 08:16 AM
Weird PSU problem phn Power Supplies 8 6th February 2007 02:42 AM
Weird amp problem Etnoo Car Audio 5 22nd August 2006 06:26 AM
Page generated in 0.08610 seconds (74.56% PHP - 25.44% MySQL) with 10 queries
