| Chip Amps Amplifiers based on integrated circuits |
#11 |
Classic ground loop. Connect both on the same outlet strip, and ensure the RCA input jacks are insulated from the chassis.
The 2050 is optimistic peak maximum, hardly the continuous output. 50 W is voltage x voltage /impedance, assuming the current output is within the chip limits. And voltage output = voltage input x gain, assuming the amplifier has the correct supply voltage. Plug the numbers in, and you get 20V into 8ohms for 50W output, a trivial task for an amp with 50V rails. I do not know what the input voltage is, but assuming it is .775V line level, you need a gain of roughly 26, or ~30dB(?) |
#12 | |
1) Input impedance resistor 33K ( It was available to me.) 2) Feedback resistor 340 R insted of 680 R ( for increase gain ) 3) Frequency stability caps : Two nos 100 nf 4) RF filtter skiped. I realise that some song (music) sounds very-very good, but in some songs (specially classical) I found bass is tearing. Is that reason I have build this circuit out of limits ? Or, Is there any way to rectify it ? Thank you & Regards. |
| Driver Choice and Maximum Output | pjpoes | Multi-Way | 7 | 4th March 2009 03:02 PM |
| How do I calculate the maximum output of a driver? | The Paulinator | Subwoofers | 2 | 21st May 2008 02:00 PM |
| LM4780: Maximum usable power output | yusuf | Chip Amps | 3 | 3rd April 2007 12:13 AM |
| Maximum transformer output | RobPhill33 | Everything Else | 4 | 17th March 2003 01:50 AM |
| Page generated in 0.07741 seconds (67.48% PHP - 32.52% MySQL) with 10 queries |
