Old 20th July 2009, 07:45 PM   #1
kizm0 is offline kizm0  United States
Default How do I find out what amperage DIY speakers take?
I want to know how to find out what Amperage my ZMV5's need.
Here's a link to the speaker build page:
http://www.zaphaudio.com/ZMV5.html
The crossover I used is this one:
http://www.zaphaudio.com/ZMV5-options-reducedBSC.gif
I know that to choose a good amp for my speakers, they should be close or spot on to the requirements of the speakers.
The amperage of the Amplifier should be equal to the monitors requirements.
The OHM rating also needs to be equal for best results.
I need somebody to completely explain this, or link me to some place that already did that.
I've googled for some time..it's probably out there..oh well thanks people.
Old 20th July 2009, 08:01 PM   #2
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
The amplifier doesn't need to supply a specific amount of current. It just needs to be capable of supplying the current required, which naturally will change dependant on the level. An amplifier with a well built power supply, high damping factor and suitable power output will supply the current needed. These speakers don't present a particularly difficult load in any case, so finding/building a suitable amp should be quite trivial
The impedance (in ohms) of the speakers that the amp can power must be considered, and is related to the current requirement. Fortunately, this speaker design is 8 ohm nominal and just about any modern amplifier will be able to power them with ease (most can do 4 ohm too, which requires more current).
If you've posted in this sub-forum as you intend to build a chip-amp to power these, then one of the many LM3886 designs should be quite suitable. I'll let someone more experienced with them elaborate on this though
Old 21st July 2009, 11:41 AM   #3
the speaker and it's crossover demands current.
It's the amplifier's job to meet this demand with as little voltage variation as possible.
Look in the spec at dBV for different load resistances.
If it drops 0.4dBV going from 8r0 to 4r0, then it supplies current well.
If it drops 1dBV, then it's mediocre to OK.
If it drops <=1.5dBV, then run ... fast. It cannot supply decent current to match the demand.
If you are looking for a 4ohm speaker compatible amplifier, then compare the 4r0 and 2r0 dBV values.
Unfortunately, few of the usual specifications tell us anything about the amplifier's ability to drive reactive loads.
BTW,
Cordell's rule of 180% power into half load resistance ~= -0.4dBV
eg. 52W (20.4Vac) into 8r0 falling to 95W (19.3Vac) into 4r0.
regards Andrew T.
Old 21st July 2009, 12:25 PM   #4
h_a is offline h_a  Europe
h_a's Avatar
This speaker appears as an easy guy to drive, don't worry about amp requirements.
Have fun, Hannes
Where to go to find info about old speakers? ChopperCharles Multi-Way 7 12th February 2008 11:51 AM
amperage and watts rtill Solid State 13 24th January 2008 09:21 AM
Where can I find A.N. custom speakers? mark_titano Multi-Way 0 8th February 2005 06:32 PM
Interesting (?) Amperage Measurements cantskienuf Chip Amps 0 13th September 2004 11:25 PM
Wire AWG & Amperage Capacity KevinLee Parts 12 10th December 2003 02:42 AM
Page generated in 0.07902 seconds (75.59% PHP - 24.41% MySQL) with 10 queries
