| Chip Amps Amplifiers based on integrated circuits |
Hi, schematic for offset regulation LS on a gainclone :
the input volume control is a stepped resistor attenuator ( attention on connecting, it is as marked ) all resistors are riken there is an offset regulation for the LS output the value of the potmeter on the offset brigde is around 500KOhm. |
#2 |
the two 10M might be a bit high. The 500k pot is too high. You should only need a few mV of input offset to generate the current to balance out the difference in the +IN & -IN resistances and chip input offset tolerance. Have a look at the Krell offset adjuster. It uses a diode across the adjustment pot to limit the range of adjustment and to lower the impedance and with it the noise that is injected into the +IN pin. There is no advantage in matching the 22k on the +IN & -IN pins. You have a 680r in parallel to one of them. The 22k on the +IN pin should be about 10times the value of the pot. If you use an unbuffered 10k pot then change the 22k to 100k or 150k. If you want to retain the 22k then consider moving the pot to a remote and convenient location and buffer it to reduce the output impedance to <=200r. You must add an RF filter to the input of you power amp PCB. Consider also adding an extra capacitor to the input RCA socket. Are you planning to add HF decoupling to the Vcc and Vee power pins? I like the way you have shown the dirty grounds coming together before the single wire connection to the Signal Ground.
regards Andrew T. |
#3 |
The 22k resistor from the non-inverting input to ground will be the determining factor for the offset and render the rest of the circuit useless.
The time constant to charge that 33µ (330µ?) capacitor through a 10 M resistor is much too long. It will take several minutes to achieve a stable voltage at the connecting point between the two 10 M resistors.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
| Gainclone with 16vdc offset | roots600rr | Chip Amps | 4 | 27th October 2008 06:48 PM |
| gainclone power supply regulation | cryo | Chip Amps | 6 | 23rd April 2008 02:56 PM |
| Measure DC offset Gainclone | wim | Chip Amps | 2 | 23rd September 2004 06:34 AM |
| Gainclone with DC-offset problems | seve | Chip Amps | 11 | 28th May 2004 11:01 PM |
| gainclone problems (dc offset, no sound) | damitamit | Chip Amps | 3 | 6th September 2003 05:24 AM |
| Page generated in 0.07241 seconds (70.71% PHP - 29.29% MySQL) with 11 queries |
