| Chip Amps Amplifiers based on integrated circuits |
I'm making a computer speaker system w/ sub and lm1875 amp for the fullrangers. I built the 1875 amp, and bolted both channels to one relatively small heatsink, and the thing doesn't get warm! I'm really surprised at how cool it stays.
I want to build all of the amps into the sub cabinet. My sub amp is a purchased plate amp. I am thinking about modding the plate amp by removing the power transformer, and moving it somewhere else. Then I will have plenty of free space for my chipamp. Do you think I can just bolt the 1875's to the steel plate of the plate amp? The plate is 10x10, but the area that is just a solid open plate, w/ no holes or other heat generating parts is about 4x10x1/8"thick. As w/ all plate amps, it also has a heatsink which the sub amp parts bolt to, and that is below the area I'm thinking of using for these 1875's. what do u think???? thanks, Scott |
#2 | ||
At the bottom of this page you can download a calculator to find out the thermal resistance of your heatsink.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 |
Thanks! That website should help.
On the 1875's now, yes, I used some 'arctic silver' thermal grease, and I do know how to use it properly. I'm used to class A amps, which is why to me, this 1875 is staying cool. The heatsink does get slightly warm, but not hot. And I think it's pretty small. 5"long, 1.5" tall, and 3/4" deep fins, and both channels are bolted to it. Also, it's the clamp type mounting, not just the single bolt through the hole on the chip. |
| Withworth bolt for AR3a? | KJ2005 | Multi-Way | 4 | 9th November 2008 08:51 PM |
| How To Cut A Nylon Bolt? | kelticwizard | The Lounge | 4 | 31st May 2008 05:20 PM |
| Steel plate speaker cabinets would they work | 56oval | Multi-Way | 3 | 26th April 2008 12:20 AM |
| mounting bolt = min pole? | Duck-Twacy | Parts | 4 | 7th November 2005 03:24 PM |
| Class A heatsinking, or heatsinking in general! | NUTTTR | Solid State | 27 | 22nd January 2005 01:48 PM |
| Page generated in 0.07532 seconds (73.76% PHP - 26.24% MySQL) with 10 queries |
