Old 14th July 2009, 11:04 AM   #1
akis is offline akis  United Kingdom
Default My final (?) PSU remote switch and slow startup for bigger transformers
This is what I have designed, and part tested with low voltages, a device to allow me to power up using a 12 V on-off switch and also provide some slow start (typical 100ms but we can easily alter this).
Please let me know what you think.
Old 14th July 2009, 11:29 AM   #2
Mooly's Avatar
You are going to think I am nitpicking now.
Your circuit looks OK at a quick glance... perhaps connect a pulldown resistor between the base/emmiter of the darlington pair, or use a single FET (2N7000) and small value timing cap, high value resistor.
For a real challenge ,why not design, so that in the off state, it draws no current. That means perhaps using a small 3.6volt backup battery to ensure self starting. A 240volt coil relay switched with an opto triac would work well.
Don't underestimate surge currents either. Thick print on the PCB and heavy duty relays required for transformers over 200/300va.
Instead of all those resistors (are you sure they will survive... you don't need that much series resistance anyway) why not try a thermistor.
Old 15th July 2009, 04:34 AM   #3
lanchile's Avatar
Well, I would say the same thing! Instead of all those resistors why not try a thermistor. I would use one in the hot and one in the neutral. all these before power transformer.
What is an Inrush Current Limiting Thermistor (Surge Limiter)?
Inrush Current Limiters are among the most common design options used in switching power supplies to prevent damage caused by inrush current surges. A thermistor is a thermally-sensitive resistor with a resistance that changes significantly and predictably as a result of temperature changes. The resistance of a Surge Limiting thermistor decreases as its temperature increases. As the inrush current limiter self-heats, the current begins to flow through it. Its resistance begins to drop and a relatively small current flow charges the capacitors in the power supply. After the capacitors in the power supply become charged, the self heated inrush current limiter offers little resistance in the circuit. So low that the voltage drop is an insignificant factor with respect to the total voltage drop of the circuit.
Some members do not feel the need for Thermistors and some do.it is all up-to the design and the project and of course the people.
Old 15th July 2009, 09:45 AM   #4
50r 25W is perfect for 300VA to 1000VA on UK voltage supplies.
With a 100ms delay they will never get warm. No matter how many times you start up your transformer in any hour.
Will it instant OFF on loss of mains power?
I still don't like the switching transistors following the slow rise of the RC time constant.
Will they pass through the conduction phase without overheating.
I'd prefer to see a fast/snap ON to reduce the time that the transistors spend with medium current and high voltage
regards Andrew T.
Old 15th July 2009, 09:49 AM   #5
wrong.
The resistance of the Thermistor modulates with changes in the amplifier current. This is easily measured seen on a scope monitoring the output voltage of the PSU and the output voltage of the amplifier fed by that PSU.
I posted results of the Krell Klone with quiescent current ~ 2.6A and even this ClassA amplifier showed this Thermistor effect.
regards Andrew T.
Old 15th July 2009, 11:39 AM   #6
Hmm , let me think. The 2pole relay will switch as soon as the capacitor feeding it gets depleted. I think it is like 300-400 Ohms and the cap is 1000uF, but the cap is also feeding the second relay, another 300-400 Ohms.
Will 400 Ohms each relay coil, and a 1000uF capacitor with no other load (for example a LED on the on/off switch) the relays will flip 200ms after loss of mains. Not sure which of the two will go first. If there is a LED or other current consumption on the 12 VDC then the relays will flip sooner, subject to their own speed of course, which is measured in 10s of ms.
But why does it matter if the circuit is an instant OFF on loss of mains?
I now see what you mean, very subtle point, and not something I had thought about, even though I did think or power/current requirements for the driver transistors and chose the BC639 which is 1A and 1W.
In the ordinary life of the circuitry, the transistor will go from OFF to ON in an instant (say 200ms), and then stay ON, it will not oscillate.
Assuming the worst, we are talking about 6 Volts into 300-400 R, that is 120mW so we should be OK.
Am I right?
Old 15th July 2009, 12:00 PM   #7
first, I would use low power 24V coil relays for the mains switches.
Second, I would use 30 to 36Vdc feed to these relays.
Third, I would run the 24V relays on ~18Vdc when pulled in, i.e. resistor in the feed to reduce running current.
Fourth, I would use a 555 as the timer, with a tiny bit of positive feedback to ensure a fast switching action for the transistor.
The instant OFF is to ensure the timer circuit resets the relays to the OFF condition ready for the next power up when the mains comes back on. The auto isolators that supply the mains (in the UK) retry to establish power after a second or two of delay from initial power down.
When the transistor is OFF the current is near zero and the voltage is Vsupply.
When the transistor is ON the current is the relay coil current and the voltage should be about Vcesat if the base current is sufficient.
For both these conditions the dissipated power is very low.
You now realise that the in between condition is the one that must be minimised to ensure reliability.
Finally, fitting that diode across the relay coil to catch the back emf pulse extends the dropout time delay. Using a Diode + Zener or Diode plus Resistor reduces the dropout delay. ESP has posted some details on his results.
What's the resistance of a 6V mains relay coil? I can't believe it only draws 17mA (350r).
regards Andrew T.
Old 15th July 2009, 01:49 PM   #8
I used 12 Volt relays and a 3.5VA 9V transformer with 10000% regulation, so I am expecting 13 volts at least. I believe the coils can be driver with 85% of the rated 12 Volts.
If you think that I need to "overdrive" the coils to start with, I could use the two 9V windings in series and get more than 25 VDC at my disposal, and then use a small resistor in series with the transistors?
I have seen this technique used, but as the consumption is just 30mA, why do we care?
OK so we want the transistor to go ON, not to go "slowly" to ON. I will think a bit more about this.
Of course and that is why I calculated Vcc/2 * Ic for the worst condition (6V into the load from a 12V supply).
What do you mean by "dropout delay"? Sorry for being thick.
It is a 12V coil, 400R, 30mA. I mentioned 6V as the worst condition in terms of power dissipation on the driver transistor.
Old 15th July 2009, 01:59 PM   #9
running the relay coil undervoltage makes it operate cooler.
running the relay coil undervoltage should allow it to drop out more quickly.
running the relay coil undervoltage may increase the reliability of the relay.
regards Andrew T.
Old 15th July 2009, 05:05 PM   #10
Iain McNeill's Avatar
Off topic and insulting posts deleted.
Please, keep your comments factual and relevant
Remote power switch Dan2 Power Supplies 10 11th February 2008 12:02 PM
remote controlled line level switch brainsalad Solid State 1 18th November 2006 02:34 PM
Creating Remote switch 93'Tempo Car Audio 1 25th April 2005 02:36 AM
Design for IR Remote on/off switch? Killjoy99 Solid State 2 8th November 2004 10:49 PM
Page generated in 0.14005 seconds (88.63% PHP - 11.37% MySQL) with 10 queries
