Old 9th July 2009, 08:11 AM   #1
ambed is offline ambed  Latvia
Default pa100
what do you think 300va 2x24v toroidal will be good for 2xpa100(stereo) suplying?
Old 9th July 2009, 10:00 AM   #2
two pa100 have a maximum output of 100W+100W.
300VA is an ideal compromise between weight, cost, volume, performance.
24+24Vac should be good for 8ohm, or 6ohm or 4 to 8ohm speakers.
4ohm speakers will take this amp to near it's limits if it is a low sensitivity design.
regards Andrew T.
Old 4th August 2009, 02:56 PM   #3
I made copy of pa100 layout from pictures. Can you tell your opinion about it?
Old 4th August 2009, 02:58 PM   #4
other side
Old 4th August 2009, 04:34 PM   #5
Old 4th August 2009, 06:46 PM   #6
You should provide a schematic, but if it is a copy of a working amplifier, what is there to opine?
If you've always done it like that, then it's probably wrong. (Henry Ford)
PA100 with DC SERVO? YFW Chip Amps 35 17th June 2007 10:17 PM
Single side PCB for PA100 zafira1981 Chip Amps 4 16th May 2006 12:02 AM
Can you tell me how to beef up PA100? leadbelly Chip Amps 5 21st March 2004 07:20 PM
PA100 power supply.. deepanger Solid State 5 14th January 2003 11:33 PM
Page generated in 0.07417 seconds (70.14% PHP - 29.86% MySQL) with 11 queries
